Hi hi,henry here
I'm working a project need to save many data to SD card,like accelerometer,encoder...
Now i'm only using accelermeter(adxl355) with ardiuno Nano.
And the results are so strange..
i connect
vcc(sd) -> 5V
vcc(accelermeter) -> 3.3V
sd_CS -> d8
accelermeter_CS -> d9
mosi(sd、accelermeter) -> d11(mosi)
miso(sd、accelermeter) -> d12(miso)
sclk(sd、accelermeter) -> d13(sclk)
gnd(sd、accelermeter) -> gnd
I can read and write accelermeter and sd card individually with the same circuit. I can not execute both actions when they are wiring to the nano.
When I’m wiring both together, I can write data to sd card,but can't read accelerometer.It wrote 0,0,0 in sd crard.
But when I cut off vcc(sd) 5v,i can read accelerometer but can't write data to sd card...
code attached~
wiring both:
cut off vcc(sd) 5v:
data:
circuit:
HELP :o :o :o :o :o
#define DEVID_AD 0x00
#define DEVID_MST 0x01
#define PARTID 0x02
#define REVID 0x03
#define STATUS 0x04
#define FIFO_ENTRIES 0x05
#define TEMP2 0x06
#define TEMP1 0x07
#define XDATA3 0x08
#define XDATA2 0x09
#define XDATA1 0x0A
#define YDATA3 0x0B
#define YDATA2 0x0C
#define YDATA1 0x0D
#define ZDATA3 0x0E
#define ZDATA2 0x0F
#define ZDATA1 0x10
#define FIFO_DATA 0x11
#define OFFSET_X_H 0x1E
#define OFFSET_X_L 0x1F
#define OFFSET_Y_H 0x20
#define OFFSET_Y_L 0x21
#define OFFSET_Z_H 0x22
#define OFFSET_Z_L 0x23
#define ACT_EN 0x24
#define ACT_THRESH_H 0x25
#define ACT_THRESH_L 0x26
#define ACT_COUNT 0x27
#define FILTER 0x28
#define FIFO_SAMPLES 0x29
#define INT_MAP 0x2A
#define SYNC 0x2B
#define RANGE 0x2C
#define POWER_CTL 0x2D
#define SELF_TEST 0x2E
#define RESET 0x2F
#include <SD.h>
#include <SPI.h>
const int SD_CS = 8; // Pin 10 on Arduino Uno
const int acc_CS = 9; //
long values[20],t[9];
double x, y, z, c;
if (!SD.begin(SD_CS)) {
Serial.println("Card failed, or not present");
pinMode(SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH);
SPI.setClockDivider(SPI_CLOCK_DIV16);
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0)); // 1000khz clock
pinMode(acc_CS, OUTPUT);
digitalWrite(acc_CS, HIGH);
writeRegister(POWER_CTL, 0x00); // writing 0 to to enable sensor
writeRegister(RANGE, 0xC1);
writeRegister(SELF_TEST, 0x00); // writing 3 to to enable
acc_data();
Serial.print(x,5);
Serial.print(',');
Serial.print(y,5);
Serial.print(',');
Serial.print(z,5);
Serial.print('\n');
digitalWrite(SD_CS, LOW);
File test0 = SD.open("test0.txt", FILE_WRITE);
if (test0) {
Serial.println("writing");
test0.print(x);
test0.print(",");
test0.print(y);
test0.print(",");
test0.print(z);
test0.print('\n');
test0.close(); // close the file
// if the file didn't open, print an error:
else {
Serial.println("error opening test.txt");
delay(10);
byte readRegister (byte thisRegister) {
byte inByte = 0 ;
digitalWrite(acc_CS, LOW);
SPI.transfer((thisRegister << 1) | 1);
inByte = SPI.transfer(0x00);
return inByte;
void writeRegister (byte thisRegister, byte value) {
SPI.transfer(thisRegister << 1);
SPI.transfer(value);
void acc_data(){
values[0] = readRegister(XDATA3);
values[1] = readRegister(XDATA2);
values[2] = readRegister(YDATA3);
values[3] = readRegister(YDATA2);
values[4] = readRegister(ZDATA3);
values[5] = readRegister(ZDATA2);
values[6] = readRegister(XDATA1);
values[7] = readRegister(YDATA1);
values[8] = readRegister(ZDATA1);
t[0] = readRegister(TEMP2);
t[1] = readRegister(TEMP1);
x = (values[0] << 12) + (values[1]<<4) + (values[6]>>4);
y = (values[2] << 12) + (values[3]<<4) + (values[7]>>4);
z = (values[4] << 12) + (values[5]<<4) + (values[8]>>4);
if (x >= 0x80000) {
x = x-(2*0x80000);
if (y >= 0x80000) {
y = y-(2*0x80000);
if (z >= 0x80000) {
z = z-(2*0x80000);
c=(t[0]<<8)+t[1];
c=((1852 - c)/9.05)+25.7;
x=x*0.0000039;
y=y*0.0000039;
z=z*0.0000039;
sd_logging.ino (3.94 KB)
