I am using the Arduino Uno R3 without wifi or Bluetooth and I made a system that records the amount of time that a location receives sunlight. I was wondering if there is a way to make the Arduino save the data it has collected at the end of every day and then later access all of this data when I bring my Arduino inside and connect it to my computer.
#include <LiquidCrystal.h>
const int pin = A0;
int rawValue = 0;
int timer;
int minutes = 0;
int hours = 0;
int seconds = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int state = 0;
bool buttonPressed = false;
bool done = false;
int loopms=50
int count = 1000/loopms;
int oneTimeDelay = 3000;
pinMode(6, INPUT);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("STARTED");
lcd.setCursor(0, 1);
lcd.print("PRESS BUTTON");
if(digitalRead(6) == HIGH){
buttonPressed = true;
else{
switch(state){
case 0:
original();
case 1:
highdetected();
case 2:
buttonPress();
case 3:
if(buttonPressed){
state = 1;
done = true;
else{
count--;
if (!count)
reader();
case 4:
stopRead();
delay(loopms);
void original(){
if(buttonPressed){
state = 1;
else{
state = 0;
void highdetected(){
if(buttonPressed){
state = 1;
else{
state = 2;
void buttonPress(){
if(done){
state = 4;
else if(buttonPressed){
state = 1;
else if(!buttonPressed){
state = 3;
void reader(){
//run code
rawValue = analogRead(pin);
delay(5);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Reading: ");
lcd.print(rawValue);
lcd.print("SunTime: ");
lcd.print(timer);
if(rawValue >= 1005){
timer += 1.0;
//end reader code
void stopRead(){
//print final results
seconds = timer;
minutes = seconds / 60;
hours = minutes / 60;
seconds = timer - (minutes * 60);
minutes = minutes - (hours * 60);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Final Sun Time: ");
lcd.print(hours);
lcd.print("hrs ");
lcd.print(minutes);
lcd.print("mins ");
lcd.print(seconds);
lcd.print("s");
delay(3000);
