saving data to sdcard
hi. am using 6dof adxl345 board https://www.sparkfun.com/products/10121 and it is working fine.
but then i try to save data to sdcard am using micro sdshield https://www.sparkfun.com/products/9802.
i downloaded the sdFat library also.
but when i try to combine both codes it doesnt save to the sd card if i connect it to the computer
please find attached my code
// Ported to SdFat from the native Arduino SD library example by Bill Greiman
// On the Ethernet Shield, CS is pin 4. SdFat handles setting SS
const int chipSelect = 8;
 SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 updated 2 Dec 2010
 by Tom Igoe
 modified by Bill Greiman 11 Apr 2011
 This example code is in the public domain.
 #include <Wire.h>
#include <ADXL345.h>
#include <SdFat.h>
SdFat sd;
SdFile myFile;
ADXL345 adxl; //variable adxl is an instance of the ADXL345 library
  adxl.powerOn();
  //set activity/ inactivity thresholds (0-255)
  adxl.setActivityThreshold(75); //62.5mg per increment
  adxl.setInactivityThreshold(75); //62.5mg per increment
  adxl.setTimeInactivity(10); // how many seconds of no activity is inactive?
  //look of activity movement on this axes - 1 == on; 0 == off
  adxl.setActivityX(1);
  adxl.setActivityY(1);
  adxl.setActivityZ(1);
  //look of inactivity movement on this axes - 1 == on; 0 == off
  adxl.setInactivityX(1);
  adxl.setInactivityY(1);
  adxl.setInactivityZ(1);
  //look of tap movement on this axes - 1 == on; 0 == off
  adxl.setTapDetectionOnX(0);
  adxl.setTapDetectionOnY(0);
  adxl.setTapDetectionOnZ(1);
  //set values for what is a tap, and what is a double tap (0-255)
  adxl.setTapThreshold(50); //62.5mg per increment
  adxl.setTapDuration(15); //625?s per increment
  adxl.setDoubleTapLatency(80); //1.25ms per increment
  adxl.setDoubleTapWindow(200); //1.25ms per increment
  //set values for what is considered freefall (0-255)
  adxl.setFreeFallThreshold(7); //(5 - 9) recommended - 62.5mg per increment
  adxl.setFreeFallDuration(45); //(20 - 70) recommended - 5ms per increment
  //setting all interupts to take place on int pin 1
  //I had issues with int pin 2, was unable to reset it
  adxl.setInterruptMapping( ADXL345_INT_SINGLE_TAP_BIT,   ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_DOUBLE_TAP_BIT,   ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_FREE_FALL_BIT,    ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_ACTIVITY_BIT,     ADXL345_INT1_PIN );
  adxl.setInterruptMapping( ADXL345_INT_INACTIVITY_BIT,   ADXL345_INT1_PIN );
  //register interupt actions - 1 == on; 0 == off
  adxl.setInterrupt( ADXL345_INT_SINGLE_TAP_BIT, 1);
  adxl.setInterrupt( ADXL345_INT_DOUBLE_TAP_BIT, 1);
  adxl.setInterrupt( ADXL345_INT_FREE_FALL_BIT,  1);
  adxl.setInterrupt( ADXL345_INT_ACTIVITY_BIT,   1);
  adxl.setInterrupt( ADXL345_INT_INACTIVITY_BIT, 1);// Initialize SdFat or print a detailed error message and halt
  // Use half speed like the native library.
  // change to SPI_FULL_SPEED for more performance.
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
  // open the file for write at end like the Native SD library
  if (!myFile.open("test.txt", O_RDWR | O_CREAT | O_AT_END)) {
    sd.errorHalt("opening test.txt for write failed");
  // if the file opened okay, write to it:
  Serial.print("Writing to test.txt...");
  myFile.println("");
  // close the file:
  myFile.close();
  Serial.println("done.");
  // re-open the file for reading:
  if (!myFile.open("test.txt", O_READ)) {
    sd.errorHalt("opening test.txt for read failed");
  Serial.println("test.txt:");
  // read from the file until there's nothing else in it:
  int data;
  while ((data = myFile.read()) > 0) Serial.write(data);
  // close the file:
  myFile.close();
  // nothing happens after setup
   //Boring accelerometer stuff
  int x,y,z;
  adxl.readAccel(&x, &y, &z); //read the accelerometer values and store them in variables  x,y,z
  // Output x,y,z values - Commented out
  Serial.print(x);
  Serial.print(",");
  Serial.print(y);
  Serial.print(",");
  Serial.println(z);
thanks
The only thing you write to the SD card is one empty string. And you do that in setup(). You then close the file so you can’t write any more to it.
You should have a file open and write your data to it. Then you might get data in your file.
Perhaps you should base your SD code on a different example. Try File->Examples->SD->Datalogger
thanks . am gonna try that 1
