Saving file list to other file
Hello,
Is it possible to save root filenames to other file like txt?
I would like to get brand new list after pushing button - clearing file etc is no problem.
I have found examples how to "print" filenames to Serial and it is clear, but no idea how "print" it to file in SD card.
You need to open the file for writing and then write each file name to the index file. Nothing happens automatically.
Use a text editor. Open the output file. Get the list of names. Instead of printing to serial, print to the file. It's not exactly rocket surgery.
It is not easy as it looks.
I tried code below, after I opened my listFile and nothing happen.
 listFile.printName();
Code for now, it is example from SdFat lib.
#include <SPI.h>
#include "SdFat.h"
const uint8_t chipSelect = SS;
SdFat sd;
SdFile file;
  // Wait for USB Serial
  while (!Serial) {
    SysCall::yield();
  Serial.println("Type any character to start");
  while (Serial.read() <= 0) {
    SysCall::yield();
  if (!sd.begin(chipSelect, SPI_HALF_SPEED)) {
    sd.initErrorHalt();
  sd.vwd()->rewind();
  while (file.openNext(sd.vwd(), O_READ)) {
    file.printName(&Serial);
    if (file.isDir()) {
      // Indicate a directory.
      Serial.write('/');
    file.close();
  Serial.println("Done!");
void loop() {}
I tried code below
in which we are supposed to guess what listFile is an instance of, and what it's printName() method does...
Here, we can see that file is an instance of the SdFile class. We can also see that printName() takes the address of a Stream instance where it is to write the name.
If you look at the SdFat.h file, you'll see that SdFile is defined as deriving from PrintFile. If you hunt around, you'll find that SdFile is implemented in FatFile.cpp, which includes FatFile.h. Both of these files are in the utility folder.
If you look at FatFile.h, you'll see that SdFile has a getName() method that allows you to get the name of the file.
char name[80];
int nameLen;
file.getName(name, &nameLen);
You can then store name in the other file.
Thanks for suggestions. All works perfect.
Code below.
void NEW_LIST(){
char name[80];
int nameLen = 40;
SD.remove("test.txt");
listFile.open("test.txt", O_CREAT | O_APPEND | O_WRITE);
SD.vwd()->rewind();
 while (tempFile.openNext(SD.vwd(), O_READ)) {
 tempFile.getName(name, nameLen);
 listFile.println(name);
 tempFile.printName(&Serial);
 tempFile.close();
listFile.close();
Is it possible to list only one type of files? For example .txt.
Yes. You have the name of the file. You can look for the last . in the name, and construct a substring of the rest of the name.. If the substring is txt, write to the file. If not, don't.
