Hello All,
My task is I have to send Serial data available in Arduino Mega (serial1 port) to Nodemcu (serial). Then from Nodemcu to MySql based database
Arduino Mega Code
String str;
// initialize serial communication at 9600 bits per second:
Serial1.begin(115200);
int sensorValue = analogRead(A0);
float voltage = sensorValue * (5.0 / 1023.0);
Serial.println(voltage);
str =String(voltage);
Serial.println(str);
Serial1.println(str);
Nodemcu Code
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
String readString;
const char* ssid = "xxx";
const char* password = "xxxx";
const char* host= "xxxxx";
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Serial.print("Netmask: ");
Serial.println(WiFi.subnetMask());
Serial.print("Gateway: ");
Serial.println(WiFi.gatewayIP());
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
void loop() { // run over and over
Serread();
postdata2();
void Serread(){
while (Serial.available()) {
delay(2);
char c = Serial.write(Serial.read()); //gets one byte from serial buffer
readString += c; //makes the String readString
// delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
readString="";
void postdata2(){
HTTPClient http; //Declare object of class HTTPClient
String url = "xxxxx"; ////Post url, now it is just url ,have to make it secure//
http.begin(url); //Specify request destination and start sending //
http.addHeader("Content-Type", "text/plain"); //Specify content-type header // here we can give json also have to test it //
int httpCode = http.POST("Message from ESP8266"); //Send the request
String payload = http.getString(); //Get the response payload, which we custom made in php to get a response//
Serial.println(httpCode); //Print HTTP return code anything not 200 is an error //
Serial.println(payload);
Serial.print("url:");
Serial.println(url);//Print request response payload //
http.end(); //Close connection//
delay(2000);
But when I observe in serial monitor,readString in Void postcode2 section is not getting printed in Serial monitor…
CAn anybody help me to resolve this
