I need to save three presets (A, B & C) to EEPROM. My attempts so far allow me to save preset "A" but nothing more. All presets save to RAM without issue. Any help much appreciated...
#include "TM1637.h" // include TM1637 library
#include <EEPROM.h>
#define CLK 2 // define TM1637 clock pin
#define DIO 3 // define TM1637 data pin
// initialize the TM1637 library
TM1637 tm1637(CLK, DIO);
//buttons for preset selection
//last 2 digits of tm1637 display (0-99)
#define UP 4 // define up button pin
#define DN 5 // define down button pin
//button for "A" "b" or "C" selection
//1st digit of TM1637 display
const int btn = 6;
//button to save settings
const int Sv = 9;
int buttonState = 0;
int num = 0, prev_num = 1;
int let = 0, prev_let = 1;
int i = 0, prev_i = 1;
const unsigned int numReadings = 3;
int storedValues[numReadings];
int Saves[numReadings];
int address1 = 0;
int address2 = 1;
int address3 = 2; // preset A
pinMode(btn, INPUT);
pinMode(UP, INPUT);
pinMode(DN, INPUT);
pinMode(Sv, INPUT);
// initialize the TM1637 display
tm1637.init();
// set display brightness (from 0 to 7)
tm1637.set(3);
EEPROM.get(address1, Saves[let]);
EEPROM.get(address2, Saves[let]);
EEPROM.get(address3, Saves[let]); // preset A
void loop ()
if (num != prev_num)
{ // if the displayed (current) number was changed
prev_num = num; // save current value of 'num'
// print all data
Serial.println(Saves[let]);
tm1637.display(2, num / 10 % 10); // print tens digit
tm1637.display(3, num % 10); // print ones digit
delay(200); // wait 200 milliseconds
if (let != prev_let)
prev_let = let; // save current value of 'let'
// print all data
tm1637.display(0, (let + 10)); //this gives me 10, 11 & 12 (A,b & C)
if (i != prev_i)
prev_i = i; // save current value of 'let'
if ( digitalRead(UP) )
{ // if the UP button is presses
num++; // increment 'num'
if (num > 99) //99
num = 0;
if ( digitalRead(DN) )
{ // if the DN button is presses
num--; // decrement 'num'
if (num < 0)
num = 99; //99
if ( digitalRead(btn) )
{ // if the btn button is presses
let++; // increment 'let'
if (let > 2) // >= 3
let = 0;
num = Saves[let];
tm1637.display(2, Saves[let] / 10 % 10); // print tens digit
tm1637.display(3, Saves[let] % 10); // print ones digit
delay(100);
buttonState = digitalRead(Sv);
if (buttonState == HIGH)
Saves[let] = num;
i++;
let = 0;
switch (let) {
case 0:
EEPROM.update(address3, Saves[let]); // preset A
case 1:
EEPROM.update(address2, Saves[let]);
case 2:
EEPROM.update(address1, Saves[let]);
An int data type (Saves declared int[]) takes 2 bytes. Your addresses are 1 byte apart.
Try with (8 bit AVR):
int address1 = 0;
int address2 = 2;
int address3 = 4;
With some processors the int data type is 4 bytes so the addresses need to be 4 bytes apart.
And use EEPROM.put() to save the values instead of EEPROM.update(). The update function only writes 1 byte. The put function writes the number of bytes in the data type (2 [or 4] for int).
The put function calls update so only write if the data changes. See the EEPROM reference.
Iβd suggest you write a simple program to save values to eeprom and read them back .( worth looking at examples)
On your sketch add some print statements to see what you actually are saving and reading back , which will identify any other errors .
Dont forget , as said, on some processors βintβ is 4 bytes , or others only two . Adjust your addressing as needed.
EEPROM.get(address1, Saves[0]);
EEPROM.get(address2, Saves[1]);
EEPROM.get(address3, Saves[2]); // preset A
Thanks @johnwasser I also found that I had to alter this accordingly...
case 0:
EEPROM.put(address3, Saves[2]); // preset A
case 1:
EEPROM.put(address2, Saves[1]);
case 2:
EEPROM.put(address1, Saves[0]);
One thing puzzles me that would be great to fix. For a preset to be saved I must cycle past that preset. How could I fix this so that a preset is saved on each press of the save button?
Look at the state change detection method to see how to perform an action only when the button state changes from, say, HIGH to LOW. The level is not important, it is the transition between one state and the other.
This example modified from the tutorial shows how to save the presets to EEPROM each time the button is pressed.
The circuit:
- pushbutton attached to pin 2 from ground
- the internal pullup on pin 2 is enabled
- LED attached from pin 13 to ground (or use the built-in LED on most
Arduino boards)
#include <EEPROM.h>
// this constant won't change:
const byte buttonPin = 12; // the pin that the pushbutton is attached to
// Variables will change:
int address3 = 0;
int address2 = 2;
int address1 = 4;
int Saves[3];
// initialize the button pin as a input:
pinMode(buttonPin, INPUT_PULLUP);
// initialize the LED as an output:
Serial.println(F("save the presets to EEPROM each time the button is pressed."));
static boolean lastButtonState = 0; // previous state of the button
static unsigned long timer = 0;
unsigned long interval = 20;
if (millis() - timer >= interval)
timer = millis();
// read the pushbutton input pin:
bool buttonState = digitalRead(buttonPin); // current state of the button
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
// if the state has changed, increment the counter
if (buttonState == LOW)
// if the current state is LOW then the button went from off to on:
Serial.println(F("Saving presets to EEPROM"));
lastButtonState = buttonState;
What was the switch case there for? It looks like you were using it to iterate through the array to save the individual array elements. It is much more efficient to use the for loop.
#include <EEPROM.h>
const int btn = 6;
const int Sv = 9;
int lastButtonState = 0; // previous state of the button
//int Saves [3];
int address1 = 0;
int address2 = 2;
int address3 = 4; // preset A
pinMode(UP, INPUT);
pinMode(DN, INPUT);
pinMode(Sv, INPUT);
tm1637.init();
tm1637.set(3);
void loop ()
// print all data
// print all data
if (i != prev_i)
if (num > 99) //99
num = 0;
if (num < 0)
num = 99; //99
let = 0;
num = Saves[let];
delay(100);
timer = millis();
bool buttonState = digitalRead(Sv); // current state of the button
With those changes, this code saves to EEPROM on each button press.
#include <EEPROM.h>
const int btn = 6;
const int Sv = 12; //9;
//int Saves [3];
int address1 = 0;
int address2 = 2;
pinMode(UP, INPUT);
pinMode(DN, INPUT);
pinMode(Sv, INPUT_PULLUP); // ***** input pullup
tm1637.init();
tm1637.set(3);
void loop ()
// print all data
// print all data
if (i != prev_i)
if (num > 99) //99
num = 0;
if (num < 0)
num = 99; //99
let = 0;
num = Saves[let];
delay(100);
unsigned long interval = 50;
timer = millis();
if (buttonState == LOW) // ****** button active LOW
But doesn't save to the EEPROM for me.
I'll post @groundFungus code here to be clear...
#include <EEPROM.h>
const int btn = 6;
//int Saves [3];
int address1 = 0;
int address2 = 2;
pinMode(UP, INPUT);
pinMode(DN, INPUT);
tm1637.init();
tm1637.set(3);
void loop ()
// print all data
// print all data
if (i != prev_i)
if (num > 99) //99
num = 0;
if (num < 0)
num = 99; //99
let = 0;
num = Saves[let];
delay(100);
timer = millis();
Just to mention again if it makes any difference @groundFungus , I'm using a Teensy 2 for this project. Pin 12 appears to be A9 on the Teensy but I've tried your code using pin 9 and pin 12 and it makes no difference.
