Saving python script to linino RAM and running script
I’m trying to run a python script that I’m saving to the linino RAM. I can’t get the arduino to return the last “print” line from my python code. Can anyone tell me what I’m doing wrong?
#include <FileIO.h>
// Setup Bridge (needed every time we communicate with the Arduino Yún)
Bridge.begin();
// Initialize the Serial
while(!Serial); // wait for Serial port to connect.
Serial.println(“File Write Script example\n\n”);
// Setup File IO
FileSystem.begin();
// Upload script used to gain network statistics
uploadScript();
// Run stats script every 5 secs.
runScript();
Serial.println(“Just ran script”);
delay(5000);
void uploadScript()
// Using /tmp stores the script in RAM this way we can preserve
// the limited amount of FLASH erase/write cycles
File script = FileSystem.open("/tmp/example.py", FILE_WRITE);
script.print("#!/usr/bin/python");
script.print(“import urllib2”);
script.print(“import ast”);
script.print(“r = urllib2.urlopen(‘https://example.com’)”);
script.print(“a = r.read()”);
script.print(“y = ast.literal_eval(a)”);
script.print(“print a[“key123”]”); //I want to index a certain part of the dictionary
script.close(); // close the file
// Make the script executable
Process chmod;
chmod.begin(“chmod”); // chmod: change mode
chmod.addParameter("+x"); // x stays for executable
chmod.addParameter("/tmp/example.py"); // path to the file to make it executable
chmod.run();
// this function run the script and read the output data
void runScript()
// Run the script and show results on the Serial
Process myscript;
myscript.begin("/tmp/example.py");
myscript.run();
String output = “”;
// read the output of the script
while (myscript.available())
output += (char)myscript.read();
// remove the blank spaces at the beginning and the ending of the string
output.trim();
Serial.println(output);
Serial.println(“just ran”);
Serial.flush();
