I have an ESP-Wroom-32, an Arducam Mega 5mp, an SD reader, and a BME680. I want to write a program that measures every 0.1 seconds with the BME680, and saves each measurement onto the SD card into a csv file along with a timestamp. Every 5 seconds, I also want to take a picture and save it to the SD card. Even if I have the camera and the SD card on different SPI buses it seems that it cannot save the image and sensor data simultaneously, so while it's saving the image I want the sensor data to be saved in the ESP's buffer. When the image finished uploading, I want it to save all data from the buffer into the csv file and clear the buffer. Is this even possible? Are there better options? (Later I'm planning to add more sensors to this setup, but I want to make it work with this sensor first. I'm planning to add an MPU9250, an SGP30, a SAM-M10Q, and a Senseair Sunrise.)
This is my current code:
#include <SPI.h>
#include <SdFat.h>
#include "Arducam_Mega.h"
#include <Wire.h>
#include <Adafruit_BME680.h>
#define CAMERA_CS_PIN 5
#define SD_CS_PIN 15
#define SD_SCLK_PIN 14
#define SD_MISO_PIN 25
#define SD_MOSI_PIN 13
SPIClass *hspi = new SPIClass(HSPI);
SdFat SD;
Arducam_Mega myCamera(CAMERA_CS_PIN);
Adafruit_BME680 bme;
int imageCounter = 1;
struct SensorData {
unsigned long timestamp;
float temperature;
float pressure;
float humidity;
float gasResistance;
const int BUFFER_SIZE = 50;
SensorData buffer[BUFFER_SIZE];
int bufferIndex = 0;
unsigned long lastMeasurementTime = 0;
unsigned long lastImageTime = 0;
const unsigned long measurementInterval = 100; // 0.1 seconds
const unsigned long imageInterval = 5000; // 5 seconds
hspi->begin(SD_SCLK_PIN, SD_MISO_PIN, SD_MOSI_PIN, SD_CS_PIN);
Serial.println("Initializing SD card");
if (!SD.begin(SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(10), hspi))) {
Serial.println("SD card initialization failed");
while (1);
Serial.println("SD card initialized");
Serial.println("Initializing camera");
if (myCamera.begin() != CAM_ERR_SUCCESS) {
Serial.println("Camera initialization failed");
while (1);
Serial.println("Camera initialized");
Serial.println("Initializing BME680 sensor");
if (!bme.begin(0x77)) {
Serial.println("BME680 initialization failed");
while (1);
Serial.println("BME680 initialized");
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setGasHeater(320, 150);
unsigned long currentTime = millis();
if (currentTime - lastMeasurementTime >= measurementInterval) {
lastMeasurementTime = currentTime;
if (bme.performReading()) {
if (bufferIndex < BUFFER_SIZE) {
buffer[bufferIndex++] = {
currentTime,
bme.temperature,
bme.pressure / 100.0,
bme.humidity,
bme.gas_resistance
Serial.println("Buffer overflow! Consider increasing the buffer size.");
Serial.println("Failed to read BME680 sensor data.");
if (currentTime - lastImageTime >= imageInterval) {
lastImageTime = currentTime;
saveImageToSD();
saveBufferToSD();
void saveImageToSD() {
Serial.println("Capturing image...");
if (myCamera.takePicture(CAM_IMAGE_MODE_HD, CAM_IMAGE_PIX_FMT_JPG) == CAM_ERR_SUCCESS) {
uint32_t imageLength = myCamera.getTotalLength();
if (imageLength == 0) {
Serial.println("Error: Image length is 0. Skipping save.");
return;
char filename[20];
snprintf(filename, sizeof(filename), "/image%d.jpg", imageCounter++);
File imageFile = SD.open(filename, O_RDWR | O_CREAT | O_TRUNC);
if (!imageFile) {
Serial.println("Failed to open file for writing.");
return;
uint8_t buffer[128];
while (imageLength > 0) {
uint8_t bytesToRead = (imageLength > sizeof(buffer)) ? sizeof(buffer) : imageLength;
myCamera.readBuff(buffer, bytesToRead);
if (!imageFile.write(buffer, bytesToRead)) {
Serial.println("Error writing to SD card!");
imageFile.close();
return;
imageLength -= bytesToRead;
imageFile.close();
Serial.print("Image saved to SD card as ");
Serial.println(filename);
Serial.println("Failed to capture image.");
void saveBufferToSD() {
File csvFile = SD.open("/data.csv", O_RDWR | O_CREAT | O_APPEND);
if (!csvFile) {
Serial.println("Failed to open CSV file.");
return;
for (int i = 0; i < bufferIndex; i++) {
csvFile.print(buffer[i].timestamp);
csvFile.print(",");
csvFile.print(buffer[i].temperature);
csvFile.print(",");
csvFile.print(buffer[i].pressure);
csvFile.print(",");
csvFile.print(buffer[i].humidity);
csvFile.print(",");
csvFile.println(buffer[i].gasResistance);
csvFile.close();
bufferIndex = 0;
Serial.println("Sensor data saved to CSV file.");
This code, when run, takes images every 5 seconds, but sensor data is not saved in the interval that the image is being saved onto the SD card. Also even when the image is not being saved the sensor doesn't save data every 0.1 seconds, but that could also be the SD card's limitation. Any help is appreciated!
