Hi, I am making project using that arducam 2mp plus and the sparkfun bme 280 atmospheric sensor and they are both saving to an sd card shield. As I have found it is beyond the capabilities of the arduino to have them write two the sd card at the same time. So I think that maybe you could have them alternate since the camera is only taking still jpegs. But I very new to arduino and I do not understand how to do it my self. Here is my code it is using two the examples from their libraries that both work individually but together only one or the other saves to the sd. Hopefully somebody smarter than me can find a solution. Thanks.
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "SparkFunBME280.h"
#include "memorysaver.h"
BME280 mySensor;
File myFile;
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined (OV2640_MINI_2MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define FRAMES_NUM 0x06
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
#define SD_CS 4
bool is_header = false;
int total_time = 0;
#if defined (OV2640_MINI_2MP_PLUS)
ArduCAM myCAM( OV2640, CS );
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.println("Reading basic values from BME280");
Wire.begin();
if (mySensor.beginI2C() == false) //Begin communication over I2C
Serial.println("The sensor did not respond. Please check wiring.");
while(1); //Freeze
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while (1) {
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55)
Serial.println(F("SPI interface Error!"));
delay(1000); continue;
Serial.println(F("SPI interface OK.")); break;
while (1) {
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))) {
Serial.println(F("ACK CMD Can't find OV2640 module!"));
else {
Serial.println(F("ACK CMD OV2640 detected.")); break;
#endif
//Initialize SD Card
while (!SD.begin(SD_CS))
Serial.println(F("SD Card Error!")); delay(1000);
Serial.println(F("SD Card detected."));
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.print("Humidity: ");
myFile.print(mySensor.readFloatHumidity(), 0);
myFile.print(" Pressure: ");
myFile.print(mySensor.readFloatPressure(), 0);
myFile.print(" Alt: ");
//Serial.print(mySensor.readFloatAltitudeMeters(), 1);
myFile.print(mySensor.readFloatAltitudeFeet(), 1);
myFile.print(" Temp: ");
//Serial.print(mySensor.readTempC(), 2);
myFile.print(mySensor.readTempF(), 2);
myFile.println(" ");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
myCAM.flush_fifo();
myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
#endif
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
total_time = millis();
while ( !myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
//Clear the capture done flag
delay(5000);
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
static int i = 0;
static int k = 0;
char str[16];
File outFile;
byte buf[256];
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //8M
Serial.println("Over size.");
return 0;
if (length == 0 ) //0 kb
Serial.println(F("Size is 0."));
return 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
i = 0;
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
Serial.println(F("OK"));
is_header = false;
myCAM.CS_LOW();
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
myCAM.CS_HIGH();
//Create a avi file
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if (! outFile)
Serial.println(F("File open failed"));
while (1);
myCAM.CS_LOW();
buf[i++] = temp_last;
buf[i++] = temp;
myCAM.CS_HIGH();
return 1;
