Saving variable using keypad
I am a beginner with Arduino
I make a code that save variable from keypad
The number I entered with the following code neither displayed on LCD nor saved to Arduino
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] =
{{'1','2','3','.'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
byte rowPins[ROWS] = {14, 15, 16, 17}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {18, 19, 20, 21}; //connect to the column pinouts of the keypad
int count=0;
Keypad kpd = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
byte index = 0;
char numbers[20]; // Plenty to store a representation of a float
float myvar;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(18, 4);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("myvar: ");
lcd.setCursor(0,2);
lolo5 = GetNumber();
int GetNumber()
char key = kpd.getKey();
if(key != NO_KEY)
if(key == 'A')
index = 0;
numbers[index] = '\0';
else if(key == '*')
numbers[index++] = '.';
else if(key >= '0' && key <= '9')
numbers[index++] = key;
else if(key == 'B')
float myvar = atof(numbers); // Do whatever you need to with len
index = 0;
You never print anything to the LCD apart from "myvar: ". Do you see that ?
Where do you expect the number to be saved?
Adding to that
You have a global and a local myvar. You also do not seem to return anything from GetNumber() so lolo5 will contain rubbish.
I am sorry
I copied the code and forget change the variable name
The code is:
lcd.setCursor(0,0);
lcd.setCursor(0,2);
myvar = GetNumber();
voidbony:
I am sorry
The code is:
lcd.setCursor(0,0);
lcd.setCursor(0,2);
So where do you print myvar ?
UKHeliBob:
So you mean to add print myvar:
The final code is:
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
//keypad
#include <SoftwareSerial.h>
SoftwareSerial mySerial(6,5);
#include <Keypad.h>
#include <Keypad.h>
{{'1','2','3','.'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
int count=0;
byte index = 0;
float myvar;
lcd.begin(18, 4);
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,2);
lcd.print(myvar);
int GetNumber()
if(key != NO_KEY)
if(key == 'A')
index = 0;
else if(key == '*')
else if(key == 'B')
index = 0;
Lose the "float" - this variable goes out of scope - use the global.
CtrlAltElite:
I am sorry Sir, I did not get what do you mean
I replace this line in code with
[code]
but without change
Your function GetNumber doesn't return anything.
If it did, you promised it would be an int, but you seem to think it ought to be a float.
Which is it?
CtrlAltElite:
Which is it?
Thanks Sir for your instructions, it is now working perfectly.
Another issue , If I need Arduino to save this variable value even if Arduino shutting down, how can I do that??
Well, te easy bit is writing it to EEPROM.
The hard bit is knowing when the Arduino is shutting down,.
Perhaps write it to EEPROM any time it has stopped changing.
CtrlAltElite:
I add the EEprom code but LCD dose not display the last value for (myvar) after restarting Arduino
Could you help?
//zzzzzzzzzzz
#include <EEPROM.h>
int address = 0;
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
//keypad
#include <Keypad.h>
#include <Keypad.h>
{{'1','2','3','.'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
int count=0;
byte index = 0;
float myvar;
  lcd.begin(18, 4);
  lcd.clear();
 lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(numbers);
lcd.setCursor(0,3);
 lcd.print(myvar);
EEPROM.update(address, myvar);
address = address + 1;
  if (address == EEPROM.length()) {
    address = 0;
myvar = EEPROM.read(address);
    address = 0;
delay(100);
float GetNumber()
   if(key != NO_KEY)
      if(key == 'C')
         index = 0;
      else if(key == '*')
         lcd.clear();
 else if(key == 'B')
lcd.clear();
      else if(key == '#')
         index = 0;
    return myvar;
[code]
You do not read the initial value from EEPROM in setup().
To compound the problem you use EEPROM.update() to write the value to EEPROM but that function only writes a byte not a float. Look at the EEPROM.put() and EEPROM.get() functions to see how to save and load a float.
UKHeliBob:
I try this code but it dose not save myvar, Any suggestion??
//zzzzzzzzzzz
#include <EEPROM.h>
struct MyObject {
  float field1;
  byte field2;
  char name[10];
float myvar;
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
//keypad
#include <Keypad.h>
#include <Keypad.h>
{{'1','2','3','.'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
int count=0;
byte index = 0;
  lcd.begin(18, 4);
  lcd.clear();
  int eeAddress = 0;   //Location we want the data to be put.
  //One simple call, with the address first and the object second.
  EEPROM.put(eeAddress, myvar);
EEPROM.get( eeAddress, myvar );
  eeAddress = sizeof(float); //Move address to the next byte after float 'f'.
 lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print(numbers);
lcd.setCursor(0,3);
 lcd.print(myvar);
float GetNumber()
   if(key != NO_KEY)
      if(key == 'C')
         index = 0;
      else if(key == '*')
         lcd.clear();
 else if(key == 'B')
lcd.clear();
      else if(key == '#')
         index = 0;
    return myvar;
Where in the code do you save it after you read it from the keypad ?
These 2 lines are in setup()
  EEPROM.put(eeAddress, myvar); //put the value of myvar (currently zero) in address zero
  EEPROM.get( eeAddress, myvar ); //reload myvar from EEPROM address zero
UKHeliBob:
Many thanks Sir , I got it. now it is working perfectly.
Should I use EEPROM.update to save memory life time?
EEPROM.update() writes a byte, not a float, so no.
However, EEPROM.put() itself uses the update() mechanism so only updates what has changed.
UKHeliBob:
Thank you so much for the help you gave me. I greatly appreciate the assistance you have provided me.
I tried to enter two variables to be saved in EEPROM but when I enter the second variable Arduino save this value for both values.
I am sure that there are some thing wrong in the code that I hope to find.
// Multi LCD
current_up = debounce(last_up, up);         //Debounce for Up button
current_down = debounce(last_down, down);   //Debounce for Down button
//----Page counter function to move pages----//
//Page Up
    if (last_up== LOW && current_up == HIGH){  //When up button is pressed
                     //When page is changed, lcd clear to print new page
      if(page_counter <2){              //Page counter never higher than 3(total of pages)
      page_counter= page_counter +1;   //Page up
      else{
      page_counter=2;
    last_up = current_up;
//Page Down
    if (last_down== LOW && current_down == HIGH){ //When down button is pressed
      if(page_counter >1){              //Page counter never lower than 1 (total of pages)
      page_counter= page_counter -1;   //Page down
      else{
      page_counter= 1;
    last_down = current_down;
//------- Switch function to write and show what you want---//
  switch (page_counter) {
case 1: {
     lcd.setCursor(0,0);
    lcd.print("Enter lo set point:     ");
    lcd.setCursor(0,2);
   lcd.print("New value:     ");
   lcd.setCursor(13,2);
    lolo5 = GetNumberr();
    lcd.print(numbers);
    lcd.setCursor(0,3);
  lcd.print("Current value:     ");
   lcd.setCursor(16,3);
  int eeAddresslo = 0;   //Location we want the data to be put.
    eeAddresslo = sizeof(float); //Move address to the next byte after float 'f'.
EEPROM.get( eeAddresslo, lolo5 );
 lcd.print(lolo);
case 2: {
      lcd.setCursor(0,0);
    lcd.print("Enter hi set point:     ");
    lcd.setCursor(0,2);
    hihi = GetNumber();
lcd.print(numbers);
lcd.setCursor(0,3);
EEPROM.get( eeAddress, hihi );
  lcd.print(hihi);
  }//switch end
float GetNumber()
   if(key != NO_KEY)
      if(key == 'C')
         index = 0;
      else if(key == '*')
         lcd.clear();
 else if(key == 'B')
lcd.clear();
      else if(key == '#')
        hihi = atof(numbers);  // Do whatever you need to with len
         index = 0;
  EEPROM.put(eeAddress, hihi);
    return hihi;
float GetNumberr()
   if(key != NO_KEY)
      if(key == 'C')
         index = 0;
      else if(key == '*')
        lcd.clear();
 else if(key == 'B')
lcd.clear();
      else if(key == '#')
        lolo5 = atof(numbers);  // Do whatever you need to with len
             index = 0;
  EEPROM.put(eeAddresslo, lolo5);
    return lolo5;
Because you're using the same address?
