Saving
I was wondering how you can save two messages from the server in two different variables on the arduino?
THANKS!
You seem to be missing quite a lot of information from your question. Care to try again?
My question was this!
#include <SPI.h>
#include <Ethernet.h>
byte mac = { 0x90, 0xA2, 0xDA, 0x0F, 0x50, 0x35 };
IPAddress arduino(192,168,0,12);
IPAddress server(192,168,0,15);
EthernetClient client;
String username = {“Admin”,“Skut”,“Arbek”,“Kubda”};
String password = {“12344”,“stra”,“124ssgra”,"!#¤%"};
Ethernet.begin(mac,arduino);
Serial.println(“Connecting…”);
if (client.connect(server, 8888)){
Serial.println(“Connected to Server”);
Serial.println(“Connecting failed”);
boolean verify(){
for(int i = 0; i < 4 ; i++){
if((username == “Admein”) && (password == “12344”)){
* return true;*
* return false;*
void loop(){
* if (client.available()){*
* char c[2];*
* for(int i = 0; i < 2 ; i++){*
_ c = client.read();
* Serial.print(c[1]);
//Serial.print(c[2]);
}*_
if (!client.connected()){
* Serial.println();*
* client.stop();*
* while(true);*
The question is! How can you save a username and a password sent from the server in two different variables o the arduino?
THis bit of "code" you posted :
if((username == "Admein") && (password == "12344")){
return true;
will not work. But you probably wrote
    if((username[i] == "Admein") && (password[i] == "12344")){
     return true;
which is why you MUST USE THE [code] [/code] tags around code so [i] shows instead of turning on italics.
until then it is too hard to read your code.
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x50, 0x35 };
String username[] = {"Admin","Skut","Arbek","Kubda"};
String password[] = {"12344","stra","124ssgra","!#¤%"};
  Serial.println("Connecting...");
   Serial.println("Connected to Server");
    Serial.println("Connecting failed");
boolean verify(){
     return true;
  return false;
void loop(){
    char c[2];
      c = client.read();
      Serial.print(c[1]);
   client.stop();
   while(true);
Could you go through the steps of what your program is doing? The logic of it? I personally don't understand the for loop.
Hello!
This is the new code! Hope you understand it this time!
#include <SPI.h>
IPAddress arduino(192,168,0,50);
String readString;
void clientRead() {
  while (client.available()) {
  //delay(10);
    if (client.available() >0) {
      char c = client.read();
      readString += c;
boolean verify(String firstText, String secondText){
  for(int i = 0; i <= 3 ; i++){
    if((firstText.equals(username[i])) && (secondText.equals(password[i]))){
      return true;
    return false;
void loop(){
  if (client.available() > 0){
    readString = "";
    clientRead();
    int n = readString.length();
    int commaIndex = readString.indexOf(';');
    int lastIndex = readString.lastIndexOf(n);
    String firstText = readString.substring(0, commaIndex);
    String secondText = readString.substring(commaIndex + 1 , lastIndex);
    Serial.println(firstText);
    Serial.println(secondText);
    Serial.println(verify(firstText, secondText));
   Serial.println("Server disconnected!");
   client.stop();
   client.flush();
   while(true);
dannable:
+1
Describing the detailed steps of the program in plain language (rather than computer code) is a great way to discover errors and uncertainties in the logic.
...R
