says void is a variable please help
int ledPin = 13p;
void setup(void) ( //initialize pins as outputs pinMode (ledPin, OUTPUT); )
void loop; ( DigitalWrite(ledPin, HIGH; delay(1000) ; DigitalWrite(ledPin, LOW); delay(1000) )
A variable name can't start with a digit.
sp. "digitalWrite"
delay(1000)DigitalWrite(ledPin, HIGH; Closing parentheses, and semicolons required.
And code tags. We love code tags
And… blocks are defined by {…} NOT (…)
Here’s your program, and what it should be, side by side:
int ledPin = 13p;                   const byte ledPin = 13;
void setup(void)                    void setup()
  //initialize pins as outputs          // initialize pins as outputs
  pinMode (ledPin, OUTPUT);             pinMode(ledPin, OUTPUT);
 void loop;                         void loop()
  DigitalWrite(ledPin, HIGH;            digitalWrite(ledPin, HIGH);
  delay(1000) ;                         delay(1000);
  DigitalWrite(ledPin, LOW);            digitalWrite(ledPin, LOW);
  delay(1000)                           delay(1000);
