Borderflight SBUS readme page does not support STM32H747. I would like to avoid modifying the files or using a serial inverter. Any suggestions?
Your topic does not indicate a problem with the Arduino CLI and hence has been moved.
I do not know if the STM32H747 does support inverted serial. And if it did, you will have to hack the core files or write your own library for it. Just use an inverter as suggested in your other topic will be the easiest way.
