scad bot obstacle giving multiple errors
#include <Wire.h>
#include <SPI.h>
#include <Pixy.h>
Pixy pixy;
uint8_t i = 0; // iterate between signatures
int state ;
//end
// Ultrasonic sensor variables
#define TRIGGER_RIGHT 4 //blue right
#define ECHO_RIGHT 3
#define TRIGGER_LEFT 9 //black left
#define ECHO_LEFT 8
#define PING_MIN_DISTANCE 60 //40 cm = 16 inches
static long rigth_sensor (void);
static long left_sensor (void);
long distance_right, duration_right;
long distance_left, duration_left;
//end
LiquidCrystal_I2C lcd(0x3F,2,1,0,4,5,6,7,3);
//setting pin for motors
uint8_t motor_left = 5;
uint8_t motor_right = 6;
int speed = 64;
//end;
// serial monotor
Serial.print(“Starting…\n”);
//lcd
lcd.begin(20,4);
lcd.clear();
pixy.init();
//motors
pinMode(motor_left, OUTPUT);
pinMode(motor_right, OUTPUT);
// //ultrasonic sensor
pinMode(TRIGGER_RIGHT, OUTPUT);
pinMode(TRIGGER_LEFT, OUTPUT);
pinMode(ECHO_RIGHT, INPUT);
pinMode(ECHO_LEFT, INPUT);
pixy.getBlocks();
Serial.println (pixy.blocks*.signature);*
_ if (pixy.blocks*.signature == 2) // signature 1*_
* state = LOW;*
* Serial.println("Stop, sig 2 ");*
_ if (pixy.blocks*.signature == 1) // signature 2*
state = HIGH;
Serial.println(“Forward , sig 1”);
switch (state)
case HIGH :{_
motor_stop();
_ lcd.setCursor(0, 2);
lcd.print("All Stop ");*_
* break;*
* case LOW :{*
* obstacle_avoid();*
* delay(1000);*
Do NOT post pictures of text. Copy and paste the text here AFTER you explain why you think the error messages are wrong. The compiler is telling you EXACTLY what the problems are.
