Scale Model Tiger I Tank Controlled by PS2 Wireless Remote
Hi this is my first post on the forum so please excuse any mistakes!
I am making a scale model Tiger 1 Tank using 3D printed parts, some motor/servos. Arduino mega, PS2 remote, and other parts. (I will include photos and the code for this project so far and the parts I am using later in the post) I plan for the PS2 remote to have one joystick control the driving and one the movement of the turret. I have been using the bill porter ps2x library fro this project, and so far I have the PS2 programmed to make tank noises and control a servo that will control the up and down motion of the main gun.
At the moment I have come across an issue using a stepper motor with the PS2 remote. Whenever I push the joystick left or right the stepper motor only spins in one direction regardless(it always spins right when I am pushing the joystick left or right). I have tried doing research to adapt what others have done but I am having trouble finding much. I was wondering if anyone had any experience doing anything like this or sees that I am missing anything, so any help would be greatly appreciated!!
PARTS (Parts marked with “/” were used in this post)
/Arduino mega 2560
/3rd party PS2 remote with wireless adapter
/Step motor 28BY-48 with ULN2003 stepper motor driver board
/SG90 Servo motor
-RC tiger chassis purchased from amazon (with built in DC motors and gearbox)
-L298N driver Board (for DC motors in chassis)
-Catalex Serial MP3 Player
-Small aux speaker
CODE
#include <Servo.h> //For driving the ESCs and Servos
#include <Stepper.h>
#include <PS2X_lib.h> // Bill Porter’s PS2 Library
PS2X ps2x; //The PS2 Controller Class
Servo GunServo; //Create servo object representing SteeringServo
int PlyStnRStickUpDn = 0; //Value read off the PS2 Right Stick up/down.
int PlyStnRStickLtRt = 0; //Value read off the PS2 Right Stick left/right
int PlyStnLStickUpDn = 0; //Value read off the PS2 Left Stick up/down
int PlyStnLStickLtRt = 0; // Value read off the PS2 Left Stick left/right
int GunServoSetting = 90; //Setting for the Steering Servo
int pos = 0;
int stickX = 128;
const int PPR = 200; // initialize steps per revolution for stepper motors
int speed = 0; // initialize stepper speed, default to 0 speed
int direction = 1; // initialize stepper direction, default to clockwise?
const int coarse = 1000; // initialize coarse speed range for motor speed mapping
Stepper stepperX(PPR, 8, 9, 10, 11); // initialize X-Stepper pins
int senXRangeMax = coarse; // initialize the X-Axis sensitivity range max speed, default to coarse
ps2x.config_gamepad(17, 15, 16, 14, false, false);
//setup pins and settings: GamePad(clock, command, attention, data, Pressures, Rumble)
GunServo.write(pos);
GunServo.attach(A8);// attaches the Steering Servo to pin 7
ps2x.read_gamepad(); //This needs to be called at least once a second
// to get data from the controller.
//Analogue Stick readings
PlyStnRStickUpDn = ps2x.Analog(PSS_RY); //Right Stick Up and Down
PlyStnRStickLtRt = ps2x.Analog(PSS_RX); //Right Stick Left and Right
PlyStnLStickUpDn = ps2x.Analog(PSS_LY); //left Stick Up and Down
PlyStnLStickLtRt = ps2x.Analog(PSS_LX); //Left Stick Left and Right
//Readings from PS2 Controller Sticks are from 0 to 255
//with the neutral being 128. The zero positions are to
//the left for X-axis movements and up for Y-axis movements.
//Variables to carry the settings for the ESCs and Servos
//The values from the PS2 Sticks are mapped to 0 to 180 degrees
GunServoSetting = map(PlyStnRStickUpDn, 256, -256, 0, 179);
GunServo.write(GunServoSetting);
stickX = ps2x.Analog(PSS_RX); // set the analog value of the right stick X-Axis equal (0-255)
int position = stickX; // set the desired stepper position equal to the X-Axis value (0-255)
speed = 0; // reset speed
direction = 1;
if (position > 130)
{ // if the X-Axis stick position is positive
speed = map(position, 130, 255, 0, senXRangeMax); // map speed based on sensitivity setting
direction = 1; // direction is positive
if (position < 126)
{ // if the X-Axis stick position is negative
speed = map(position, 0, 126, senXRangeMax, 0); // map speed based on sensitivity setting
direction = -1; // direction is negative
if (speed > 0)
{ // if the X-Axis joystick is not in the center dead zone, move stepper motor
stepperX.setSpeed(speed); // set X-Axis stepper speed
stepperX.step(direction); // go set number of steps in specified direction
delay(5);
If you have any questions do not be afraid to ask!
PS2_Joysticks.ino (3.01 KB)
Have you tried something like the one revolution stepper example to demonstrate that you can rotate the stepper both ways? It would prove out your wiring.
If so, try serial.println to show you what value you’re getting from the joystick.
Did you have a good reason not to post your code?
AWOL: Did you have a good reason not to post your code?
It says I posted it, I attached the .ino file. Is the image that I also attached not showing up, it says they were both downloaded a few times?
wildbill:
I have not tried that yet, but I definitely will. I originally thought that the arduino was confusing the input from the joystick. Thanks for the help Wildbill!
I am trying to make my own ps2 controlled tank but with an Arduino Uno. does that still work for this application and do you by chance have a wiring diagram that I can follow? thank you in advance!!
