Scaling analog readings to stable values
Hello,
I am trying to scale my analog readings and I get into a problem of ‘unstable’ values.
My goal is to scale 0-1023 to 50-250. I am using the map function – map(A0, 0, 1023, 50, 250). I have set up a display to check the values.
The problem is that sometimes I run into ‘middle’ values, where the display is flickering between two – for example 69 and 70.
How would you approach this topic? Some DSP low-pass filtering?
Thanks for any help!
Post your code using the "#" tool button and we can talk about it.
int value;
  value = map(analogRead(0), 0, 1023, 50, 250);
  show_me_on_display(value);
there is nothing else then what i've already described
mrkva: Hello,
I am trying to scale my analog readings and I get into a problem of 'unstable' values. My goal is to scale 0-1023 to 50-250. I am using the map function – map(A0, 0, 1023, 50, 250). I have set up a display to check the values.
The problem is that sometimes I run into 'middle' values, where the display is flickering between two – for example 69 and 70. How would you approach this topic? Some DSP low-pass filtering?
Usual first method is to try to take multipule samples and divide by the number of samples taken, thus getting a average value. That acts like a first order low pass filter. Start with maybe 8 samples, divide by 8 then perform your map function. If that settles down the value you can then try with just 4 samples, etc.
Lefty
You might try a dead band setup like in the below code.
//zoomkat dual pot/servo test 12-29-12
//view output using the serial monitor
#include <Servo.h>
Servo myservoS1;
Servo myservoS2;
int potpinS1 = 0;  //analog input pin A0
int potpinS2 = 1;
int newvalS1, oldvalS1;
int newvalS2, oldvalS2;
  myservoS1.attach(2);
  myservoS2.attach(3);
  Serial.println("testing dual pot servo");
  newvalS1 = analogRead(potpinS1);
  newvalS1 = map(newvalS1, 0, 1023, 0, 179);
  if (newvalS1 < (oldvalS1-2) || newvalS1 > (oldvalS1+2)){
    myservoS1.write(newvalS1);
    Serial.print("1- ");
    Serial.println(newvalS1);
    oldvalS1=newvalS1;
  newvalS2 = analogRead(potpinS2);
  newvalS2 = map(newvalS2, 0, 1023, 0, 179);
  if (newvalS2 < (oldvalS2-2) || newvalS2 > (oldvalS2+2)){
    myservoS2.write(newvalS2);
    Serial.print("2- ");
    Serial.println(newvalS2);
    oldvalS2=newvalS2;
  delay(50); //slow down looping to better read serial monitor
I would use a single stage butter worth filter on the data I assume you have a known sample time interval, so just google code samples in C for simple butterworth filters utilities that to limit the effects of random results etc. Alternatively use a moving average with dead band on the raw data this however will not exclude random read results that will occur due to extenrnal influences.
So the ideal is a filter first followed by a moving average IMO.
Happy coding // 8) 8)
