hello, i want to print two different barcode and different digits number with barcode scanner, print the date and print the output from my weighing scale with zebra label printer.
i use arduino mega, barcode scanner enibit bs90, arduino usb host shield, two rs232tottl, zebra label printer gk420d and ds3231
i can print 1 barcode with same digit number (example: 0009285201 or 0123456789 or something with 10 digits)
#include <hid.h>
#include <hiduniversal.h>
#include <usbhub.h>
#include <Usb.h>
#include <hidboot.h>
#include <avr/pgmspace.h>
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
const byte BarcodeLength = 11;
const byte WeightLength = 15;
const int buzzer = 2;
class BarcodeReader : public KeyboardReportParser
USB Usb;
USBHub Hub;
HIDUniversal Hid;
HIDBoot<HID_PROTOCOL_KEYBOARD> Keyboard;
uint8_t buffer[BarcodeLength + 1];
byte length;
bool valid;
void addCharacter(uint8_t c);
public:
BarcodeReader();
void begin();
void task();
const uint8_t* barcode();
void reset();
protected:
virtual void OnKeyDown(uint8_t mod, uint8_t key);
BarcodeReader::BarcodeReader()
: Usb()
, Hub(&Usb)
, Hid(&Usb)
, Keyboard(&Usb)
, length(0)
, valid(false)
void BarcodeReader::begin()
if (Usb.Init() == -1) {
Serial.println("OSC did not start.");
Hid.SetReportParser(1, this);
void BarcodeReader::task()
Usb.Task();
void BarcodeReader::addCharacter(uint8_t c)
if (valid) {
// already have a barcode, new one will overwrite it
reset();
// could check for \n or \r if necessary, or even implement a timing
// mechanism for detecting end of barcode input, but for now we just
// assume fixed width field with no output separators
buffer[length++] = c;
buffer[length] = '\0';
if (length == BarcodeLength) valid = true;
// return value no longer valid after another call to task()
const uint8_t* BarcodeReader::barcode()
return (valid) ? buffer : 0;
void BarcodeReader::reset()
length = 0;
valid = false;
void BarcodeReader::OnKeyDown(uint8_t mod, uint8_t key) {
uint8_t c = OemToAscii(mod, key);
if (c) addCharacter(c);
class WeightReader
uint8_t buffer[WeightLength + 1];
byte length;
bool valid;
public:
WeightReader();
void begin();
void task();
const uint8_t* weight();
void reset();
WeightReader::WeightReader()
:length(0)
,valid(false)
void WeightReader::begin()
Serial2.begin(9600);
void WeightReader::task()
if (Serial2.available()) {
uint8_t c = Serial2.read();
if (valid) {
// already have a weight, new one will overwrite it
reset();
switch (c) {
case '\r': // discard carriage return
case '\n': // end of weight
if (length == WeightLength) {
valid = true;
// missed the beginning of the weight
reset();
default: // store weight characters
if (length < WeightLength) {
} else
// unexpected output from scales; should never happen
reset();
const uint8_t* WeightReader::weight()
void WeightReader::reset()
length = 0;
valid = false;
BarcodeReader barcodeReader;
WeightReader weightReader;
pinMode(buzzer,OUTPUT);
Serial3.begin(9600);
barcodeReader.begin();
weightReader.begin();
rtc.begin();
//The following lines can be uncommented to set the date and time
// rtc.setDOW(TUESDAY); // Set Day-of-Week to SUNDAY
// rtc.setTime(11, 55, 0); // Set the time to 12:00:00 (24hr format)
// rtc.setDate(07, 12, 2017); // Set the date to January 1st, 2014
barcodeReader.task();
weightReader.task();
const char* barcode = barcodeReader.barcode();
const char* weight = weightReader.weight();
if ( (barcode) && weight[0] =='S') {
Serial.println(barcode);
Serial.println(weight);
Serial.println(rtc.getDateStr());
Serial3.println("^XA");
Serial3.println("^LH24,24");
Serial3.println("^FO0,5");
Serial3.println("^A0,20,20");
Serial3.println("^FDBATCH: ");
Serial3.println(barcode);
Serial3.println("^FS");
Serial3.println("^FO0,25");
Serial3.println("^FDBERAT: ");
Serial3.println(weight);
Serial3.println("^FO0,45");
Serial3.println("^FDTGL : ");
Serial3.println(rtc.getDateStr());
Serial3.println("^XZ");
barcodeReader.reset();
weightReader.reset();
if ( (barcode) && weight[0] =='U')
Serial.println("alarm euy");
tone(buzzer,1500);
delay(200);
noTone(buzzer);
delay(200);
tone(buzzer,1500);
delay(200);
noTone(buzzer);
and print results is:
BATCH: 0009285201 -------> FROM BARCODE SCANNER
BERAT: ST,+00018.70 g---> FROM WEIGHING SCALE
TGL : 29-01-2018---------> DATE FROM DS3231
this is what i want : example: i have 2 barcode with different digits (1:0009285201 2:01234567).
- i scan barcode 1 with barcode scanner
- i scan barcode 2 with barcode scanner
- i send data from my weighing to arduino
- i print them to zebra label printer
and print results what i want is:
BATCH: 0009285201 -------> BARCODE 1 FROM BARCODE SCANNER
ID : 01234567 ----------> BARCODE 2 FROM BARCODE SCANNER
just ignore weighing scale and ds3231 (because i think its okay no problem). what should i do?
Thank you....
