es geht um einen Batterieüberwachung auf einem Gartengrundstück welches mit einer Richtfunkstrecke angebunden ist, hierbei habe ich Probleme Thingspeak einzubinden und stehe auf dem Schlauch vielleicht kann mir einer weiter helfen.
Gruß Markus
hier mal der Code
#include <ThingSpeak.h>
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ 50
#define VOLTAGE_MAX 16.0
#define VOLTAGE_MAXCOUNTS 1023.0
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xff, 0x75, 0x45, 0xED };
IPAddress ip(192, 168, 1, 10); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile; // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
unsigned long myChannelNumber = 11111; // Thingspeak
const char * myWriteAPIKey = "XXXXXXXXXXX"; // Thingspeak
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.htm")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
ThingSpeak.begin(client);
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
// remainder of header follows below, depending on if
// web page or XML page is requested
// Ajax request - send XML file
if (StrContains(HTTP_req, "ajax_inputs")) {
// send rest of HTTP header
client.println("Content-Type: text/xml");
client.println("Connection: keep-alive");
client.println();
// send XML file containing input states
XML_response(client);
else { // web page request
client.println("Content-Type: text/html");
client.println();
// send web page
webFile = SD.open("index.htm"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.print(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
int sensorValue = analogRead(A2);
float voltage = sensorValue * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
// send the XML file containing analog value
void XML_response(EthernetClient cl)
int analog_val;
cl.print("<?xml version = \"1.0\" ?>");
cl.print("<inputs>");
// read analog pin A2
analog_val = analogRead(2);
cl.print("<analog>");
cl.print(analog_val);
cl.print("</analog>");
cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
ThingSpeak.writeField(myChannelNumber, 1, voltage, myWriteAPIKey);
delay(20000); // ThingSpeak will only accept updates every 15 seconds.
Ich bin dermaßen eingerostet in Sachen Programmierung das ist Jahre her letzte Projekt war 2011 für ein Ballonprojekt.
Ziel ist es auf der Webseite welche auf der SD Karte ist mit einem Frame zusätzlich zu dem visuellem Anzeigeinstrument den Spannungsverlauf zeitlich einzubinden um zu sehen wie die Solarzellen nachladen, später noch dazu den Ladestrom.
Laufen sollte das auf einem Uno den ich aus dem Ballonprojekt liegen habe schon wegen dem Stromverbrauch es reich das der Richtfunkspiegel 350mA aus dem 12V saugt. deswegen auch ein DCDC Wandler Verwendung findet.
Die Bibliothek Thinkspeak.h nimmt Dir viel Aufwand ab.
Ich kann Dein Problem nicht nachvollziehen, da ich mit einem nodemcu arbeite.
Und wie hier angegeben könnte es funktionieren.
Ich habe mein Programm noch einmal überarbeitet. Es kompiliert jetzt einwandfrei. Da ich weder ein Ethernet oder Wifi Shield habe kann ich leider nicht sagen ob es bei Dir läuft.
Daher wäre Feedback nett.
Ich verwende ein nodemcu.
#include <WiFi.h>
int status = WL_IDLE_STATUS; // the Wifi radio's status
// replace with your channel’s thingspeak API key,
const char * myWriteAPIKey = "ABCDEFGHIJKL";
unsigned long myChannelNumber = 123456;
// Local AP Credentials
char ssid[] = "yourNetwork"; // your network SSID (name)
char pass[] = "secretPassword"; // your network password
WiFiClient client;
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
while (status != WL_CONNECTED) {
status = WiFi.begin(ssid, pass);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
int sensorValue = analogRead(2);
// fill data fields (max 8 fields) and update
ThingSpeak.setField(1, voltage);
ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
Probier es einfach mal aus.
Und hier mit Ethernet. Wobei die gleichen Einschränkungen gelten wie für der oben genannten Code.
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.google.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
delay(10);
Serial.print("Connecting .... ");
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
habe es hinbekommen laut aber nur auf dem Mega sauber
Gruß Markus
#include <SPI.h>
#include <SD.h>
unsigned long myChannelNumber = 170185; // Thingspeak
const char * myWriteAPIKey = "FLULHAQJ4A4YOHY0"; // Thingspeak
if (!SD.begin(4)) {
req_index++;
client.println();
client.println();
// send web page
if (webFile) {
webFile.close();
req_index = 0;
if (c == '\n') {
int analog_val;
str[i] = 0;
char found = 0;
char index = 0;
char len;
len = strlen(str);
return 0;
found++;
return 1;
else {
found = 0;
index++;
return 0;
