Schematic of and old dumb terminal.
Hi!
I recently salvaged an old dumb terminal from a telephone system. My plan is to interface the keyboard and find some sort of video input so that I can use it in future projects with an Arduino. Now, all the information I have about this device is attached below, but even though I was able to find an user manual (in French) I could not find an electrical diagram. Should somebody know some website where I could find it, I would be very grateful.
Write to Alcatel and ask them.
Pinouts for DIN connector and Arduino support here: https://github.com/01010101/Minitel
The DIN connector only has audio, already tried that
Do you think Alcatel would answer?
Write to them and let us know!
Atomillo:
Audio?
The DIN connector is supposed to have TX-RX at 1200 Baud on 5V Open collector outputs and TTL levels.
Perfect to interface with an Arduino. Forget video.
The connecor also provides 8,5 V that would have been perfect to feed Vin.
IUMHO you will not need a schematic.
All persons who did work on that device @ Alcatel are probably retired.
You may ask, but don't be disapointed if you get no answer...
P.S: the thread would have been better localized in "Device Hacking".
Have a look here:
http://minitel.org
Mostly french, but google translate is your friend :slight_smile:
Basically it's a serial terminal with integrated modem. Easy to interface with an arduino (bypassing the modem part).
