Hello,
I have a project where I use this exact schmitt trigger to debounce a pushbutton. When I push the button nothing happens at the digital pin on the Arduino. I think it just floats. Actually, I use an embedded Atmega328. When I press the Atmega a bit with my finger, the state of the pin changes from 0 to 1 or vice versa regardless of the state of the pushbutton. So far, this looks like a floating pin. I measured the voltages, the schmitt trigger output pin was ok (5V), and I made a continuity test from the output to the arduino digital pin and it was also good. However, I can't measure 5V on the arduino digital pin. The voltage just goes away?! Then, I noticed that when I connect my multimeter between the schmitt trigger output and GND, everything works fine. What causes this? I hope it is nothing serious because it is quite hard to modify the circuit on the pcb.
