Hello,
I am a middle school student and I would like to use Arduino in my science fair project. I have an idea to basically build a scanner you can use to scan unknown animal/insect bites and to be able to get results on which animal might have bit you. I am new to Arduino programming and am unsure how to program this. Also, what materials do i use for this project?
What do you mean by scanning? Do you mean have a camera that looks at the bite to assess it? I don't think anyone can tell definitively by just looking at a bug bite which bug bit you.
I think you'd need to identify toxins, enzymes, and bacteria to identify which bug bit you. That is going to take some pretty heavy duty chemical sensing.
I wish I had been using Arduino in middle school, that is really cool. That said, identifying a bite by visual means could be very hard. The programming would probably be very advanced and might involve machine learning. I as a college electrical engineering student would consider it beyond my programming skills, but I am more of a hardware person.
What I can say is that this type of visual identification would likely need something with more processing power and more memory. A smartphone app would be more doable, but even that may need a server to crunch the numbers. The other issue is that bites look very similar and may be indistinguishable visually.
You can certainly take a stab at it, but realize that this would be a challenging problem for anyone on this forum and even the likes of Google or Microsoft.
Very cool to hear your ambitious plans!
Hopefully you can continue to do some research and find a way to make this possible.
However, image inspection at the level you're talking about is on par with industrial vision applications.
Typically, I see this done with a dedicated, hardened industrial controller known as a PLC. These provide tools known as "blocks" required to communicate with the camera. (Usually through TCP/IP)
Arduino is not good at image processing.
You'd have more chance to do it in a reasonable amount of time with a Raspberry Pi, or even a full fledged computer.
