Scope Resolution Operator ::
I am testing out the Scope Resolution Operator :: Here is my code ...
class Sensor { public: float temperature = 33.8; };
Sensor MySensor;
float temperature = 22.16;
void setup() { Serial.begin(9600); }
void loop() { Read_Temperature(); }
void Read_Temperature(){ float temperature = 28.77; Serial.println(temperature); Serial.println(::temperature); Serial.println(MySensor::temperature); delay(5000); Serial.println(); }
I get an error "MySensor is not a class, namespace, or enumeration" Not sure what the issue is? Any help gratefully received. Thanks
  Serial.println(MySensor.temperature);
Thank you "wildbill", worked perfectly Thanks for your quick reply
If you want to reference a class static member variable you can use the class name for the scope:
class Sensor
  public:
    static constexpr float temperature = 33.8;
Sensor MySensor;
  Read_Temperature();
  Serial.println(temperature);  // Local
  Serial.println(::temperature);  // Global
  Serial.println(Sensor::temperature);  // class static
  delay(5000);
