I am doing a project on a solar tower. I got two VTI-SCP1000 sensors. I would like to know whether I could read temp and pressure data from both sensors using the same arduino-uno controller as well as reading the wind speed data from the anemometer
From a brief reading of the datasheet, there are two version one for TWI (I2C) and one for SPI.
Which have you got?
(there appears to be only a single TWI address, so this option will be tricky if you want to put two into the same Arduino)
I was going to use spi interface, cant u use spi interface to have two sensors? I decided to use spi as there r many codes online available where as TWI havent found any,how do u do this woth TWI.help pls!
You can use the PD pin on the TWI devices as a chip select and run two in parallel. I built a weather station that uses that part but so far I can't find the schematic and the sketch that I used. If I remember correctly you could also wire the SDA pins together and control the individual chips with separate SCL lines.
