Screeching sound in Arduino uno
I improved my code but why is there only a screeching sound when I connect to ARDUINO。
#include <funshield.h>
int LEDS[] = { 1, 2, 3, 4 };
bool STATES[] = { true, true, true, true, true };
// Pins are different between Arduino and Attiny
#if defined(__AVR_ATtiny85__)
#define ARDUINO 0
#define ledPin 0
#define lightPin 3    // CdS or pushbutton hooked from PB4 (Pin 3, A2/D4) to ground
#define lightPullUp 3
#define touchPin 1
#define touchPullUp 2
#else
#define ARDUINO 1
#define ledPin 9  // RGB red
#define lightPin A1
#define lightPullUp A1
#define touchPin A3
#define touchPullUp A3
#endif
int on_time = 10;  // in seconds
#if (ARDUINO)
    Serial.println("SMD_heart");
#endif
    // setup heart pin
    pinMode(ledPin, INPUT);
    // setup other LEDs
    for (int LED = 0; LED < (sizeof(LEDS) / sizeof(int)); LED++) {
        pinMode(LEDS[LED], OUTPUT);
        digitalWrite(LEDS[LED], STATES[LED]);
    heartBeat(on_time);
boolean heartBeat(int on_time) {
    // based on http://dlnmh9ip6v2uc.cloudfront.net/datasheets/E-Textiles/Lilypad/LilyTiny.ino
    // Variables and constants for fading pin. Needs to be a hardware PWM pin; on
    byte heartStage = 0;
    int heartBrightness = 0;
    byte heartCounter = 0;
    long off_time = millis() + on_time * 1000;
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, HIGH);
    while (millis() < off_time) {
        delayMicroseconds(9999);
        // calculate brightness for heartbeat pin (by cycling
        // through phases of pulse pattern)
        heartCounter++;
        if (heartCounter > 144) {
            heartStage = (heartStage + 1) % 4;
            heartCounter = 0;
        else {
            switch (heartStage) {
            case 0:
                analogWrite(ledPin, heartBrightness);
                heartCounter += 144 / 12.0;
                heartBrightness += 255 / 12.0;
                if (heartBrightness > 255)
                    heartBrightness = 255;
            case 1:
                heartCounter += 144 / 24.0;
                heartBrightness -= 255 / 24.0;
                if (heartBrightness < 0)
            case 2:
            case 3:
                heartCounter += 144 / 72.0;
                heartBrightness -= 255 / 72.0;
            }//switch
        }//else
        // blink other LEDs randomly
            if (random(40) == 1) {
                STATES[LED] = !STATES[LED];
    // go to a low power state
    digitalWrite(ledPin, LOW);
    return(true);
Oops
can i know whats the problem is?
must to be ledPin or some other problems?
It's the '1'
This should be:
  unsigned long start_time = millis();
  while (millis() - start_time < on_time * 1000)
Always subtract a start time from the current time to get an elapsed time. Otherwise, things go bonkers when the timer rolls over after 4.2 billion milliseconds.
thank you very much
