below is some code that reads a straingauge input via a HX711 then displaying the weight on a graph.
I wish to have a hidden button that clears the screen and then I can add the Scale factor in to calibrate the output of the HX711 to read Kg.
All working so far, problem is when I hit the hidden button the screen clears to Black, but the graph, alarm button and Alarm line redraw on the screen. I understand why they do it, because the loop is still running, what I want help with is the best method (read easiest) to solve the issue so these dont show. I could put in an If in the calibrate screen, but am sure there is a more elegant solution, I just cant think of it.
Thanks
Sutto55
#include <pin_magic.h>
#include <registers.h>
#include <HX711.h>
#include <TouchScreen.h>
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#define DOUT A14
#define CLK A15
#include <SPI.h> // f.k. for Arduino-1.5.2
#include "Adafruit_GFX.h"// Hardware-specific library
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GREY 0xCE79
#define LIGHTGREY 0xDEDB
// These are the pins for the shield!
#define YP A3 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 9 // can be a digital pin
#define XP 8 // can be a digital pin
#define MINPRESSURE 60 //touch screen pressure Minimum
#define MAXPRESSURE 1000 // Touchscreen pressure Maximum
#define relayPin 49 //will turn on to power the relay when the Actual weight is < the alarm setpoint
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
long int sensor1Val = 0; // used to hold sensor data. This is read via I2C on pins A14 and A15. This is a data stream, not an analog value. The HX711 sends out 24 bits of data
int sensor1ValOld = 0; // holds previous value for line graph
int Alarm = 110; // Just an initial value
int AlarmPoint; // setpoint that is the trip point for the weight
int oldAlarmPoint; //used to check if the Alarm point has been changed
int oldAlarm;
int Xposn = 51, Yposn;
int Weight;
int Kg;
int oldKg = 0;
int plotVal ; //the weight read from the strain gauge
int oldPlotVal; //used as the start point of the line on the graph. The program draws a line between the oldPlotVal to plotVal so it is a continuous line and not a row of dots
bool AlarmTripped = false; // used to test when the alarm has been exceeded and waits for a reset touch on the screen to latch out the speed control signal
float ScaleValue;
HX711 scale(DOUT, CLK); //Send scale factor to the HX711
float calibration_factor = -7050;
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH); // turn sensor power on
scale.set_gain(128);
tft.drawRect(50, 0, 319, 200, BLUE); // draw the graph outline
scale.tare(); // reset the scale to 0
int i = 0;
// Draw crosshairs {
tft.reset();
uint16_t identifier = 0x7783;
tft.begin(identifier);
tft.fillRect(0, 0, 240, 320, BLACK);
tft.setRotation(3);
tft.drawRect(50, 1, 270, 200, BLUE);
// for (int i = 0; i < 200; i += 9) {
// tft.drawLine(45, i, 50, i, BLUE);
//all the following just setup the screen display that does not change
tft.fillRoundRect(10, 205, 50, 30, 8, GREEN);
tft.fillRoundRect(80, 205, 50, 30, 8, GREEN);
tft.setCursor(17, 215);
tft.setTextColor(BLACK);
tft.setTextSize(2);
tft.print("INC");
tft.setCursor(87, 215);
tft.setTextSize(2);
tft.print("DEC");
tft.setTextColor(YELLOW);
tft.setTextSize(3);
tft.setCursor(280, 210);
tft.print("Kg");
tft.fillCircle(160, 220, 15, GREEN);
scale.set_scale(2427);
void loop () {
int AlarmLine;
//Read Value from Strain Gauge and send
//it to Tension Function then return calculated weight.
Kg = scale.get_units(4); //Raw Value in KG after scaling in the HX711
Serial.println(Kg);// the calculated Kg is sent to the Serial port and can be monitored with the Serial Monitor. It can also be graphed on the serial plotter
if (Kg < 0)Kg = 0;
//Kg=0;
plotVal = (-.829 * Kg) + 200;
//Serial.println(plotVal);
tft.drawLine(Xposn, oldPlotVal, Xposn + 1, plotVal, YELLOW);// line drawing on the graph from oldPlotVal to PlotVal and incrementing by 1 pixel
//delay(100);
if (plotVal != oldPlotVal) {
oldPlotVal = plotVal;// moving the new plotVal into oldPlotVal as the start of the line for the next value
if ( Kg != oldKg ) {
oldKg = Kg;
tft.fillRect(220, 210, 60, 40, BLACK);// dispaly the Kg value at the bottom RH of the screen
tft.setTextSize(3);
tft.setCursor(220, 210);
tft.print(Kg);
// this increments the pixel for the next point on the graph
Xposn = Xposn + 1;
if (Xposn > 317) {
Xposn = 52;
tft.fillRect(51, 2, 268, 197, BLACK);// and this clears the plot area and resets the cursor to the LHS of the plot screen
AlarmLine = AlarmLevel ();// calculation of the Alarm line
AlarmPoint = (-0.829 * Alarm) + 200 ;
tft.drawLine (52, AlarmPoint, 318, AlarmPoint, RED);
tft.setTextColor(RED);// draw the alarm line
tft.setTextSize(2);
tft.setCursor(0, (AlarmPoint - 10));
if (Alarm != oldAlarm) {// overwrite the red line with a black line if the Alarm Level is changed
tft.fillRect(0, (AlarmPoint - 20), 40, 33, BLACK);
tft.print(Alarm);
oldAlarm = Alarm;
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); // these lines capture a screen press and resets AlarmTripped value from True to false
pinMode(XM, OUTPUT);
if (p.z > ts.pressureThreshhold) {
Serial.println("Im in here");
if (Kg > Alarm & ! AlarmTripped ) { // the lines here look for Kg to be > alarm and NOT AlarmTripped. If true this sets the AlarmTripped Var to true
AlarmTripped = true;
switch (AlarmTripped) {// this evaluates if the AlarmTripped value and either latches the Relay off or On
case 0:
digitalWrite (relayPin, HIGH);
case 1:
tft.fillCircle(160, 220, 15, RED);
digitalWrite(relayPin, LOW);
if (p.x > 784 && p.x < 902 && p.y > 76 && p.y < 180){
tft.fillScreen(BLACK);
delay(100);
// the below function looks at which button is pressed INC or DEC and moves the Alarm level to the required value. It is limited to 10 and 240
int AlarmLevel() {
if (p.x > 128 && p.x < 200 && p.y > 764 && p.y < 860) {
tft.drawLine (52, ((-0.829 * Alarm) + 200), 318, ((-0.829 * Alarm) + 200), BLACK);
Alarm = Alarm + 10;
if ( Alarm > 240) {
Alarm = 240;
if (p.x > 128 && p.x < 200 && p.y > 592 && p.y < 690) {
Alarm = Alarm - 10 ;
if (Alarm < 10) {
Alarm = 10;
return Alarm;
