Hey my Script work if i upload it and have th arduino connected to my computer, but it does not run if i put it on a charging port.
This is the Script:
#include <Arduino.h>
#include <SoftwareSerial.h>
#include <FastLED.h>
#include <DFRobotDFPlayerMini.h>
#define ANZAHL_LEDS 12
#define HELLIGKEIT 100
#define LED_PIN 6
#define CLOCK_PIN 13
CRGB leds [ANZAHL_LEDS];
int gelb = 3; // LED Pin
int rot = 4;
int sensor=A0; // Der Signal Pin vom Sensor
int sensorstatus=0; // Status vom Sensor
int TasterPin=2;
int val,x=0;
int kraft=analogRead(A0);
int y = 0;
uint8_t BlinkValue = 0; // Blink-Status
uint8_t TasterValue = 0; // Taster-Status
uint8_t status = 0;
uint8_t type;
unsigned long actTime = 0;
unsigned long remTime = 0;
const long interval = 1000;
bool is_blue = false;
int random_zaehler = 0;
SoftwareSerial mySoftwareSerial(10,11); // RX, TX, Lautsprecher
DFRobotDFPlayerMini myDFPlayer;
uint8_t getDetail(uint8_t type){
return type;
int random_int(int min, int max)
return min + rand() % (max+1 - min);
pinMode(gelb, OUTPUT); // LED als Ausgang definieren
pinMode(rot, OUTPUT);
pinMode(sensor, INPUT); // Sensor als Eingang defnieren
pinMode(TasterPin, INPUT);
FastLED.addLeds<NEOPIXEL, LED_PIN>(leds, ANZAHL_LEDS);
FastLED.setMaxPowerInVoltsAndMilliamps(5,1000);
FastLED.setBrightness(HELLIGKEIT);
mySoftwareSerial.begin(9600);
//Serial.begin(115200);
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true){
delay(0); // Code to compatible with ESP8266 watch dog.
Serial.println(F("DFPlayer Mini online."));
kraft = analogRead(A0); //Auslesen der Sensormesswerte -> "helligkeit"
//Serial.println(analogRead(A0)); //Ausgabe der Sensormesswerte
if (kraft > 120 && y==0){ // wenn sich Bobbi hinsetzt....
//Serial.println("Bobbi sitzt");
delay(3000); // ... wartet Buzz 10 Minuten (hier 2 Sekunden)
y = 1;
if (kraft > 120 && y==1){ //wenn der Messwert unter 50 ist (und Bobbi immer noch sitzt)...
y = 2; // wird y auf 2 umgeschaltet und zeigt an, dass dies der zweite Messwert ist.
//Serial.println("Bobbi sitzt jetzt 30 Minuten");
if (kraft < 120 && y==1){ //wenn der Messwert über 200 ist (und Bobbi aufgestanden ist)...
y = 0; // wird y auf 0 zurückgeschaltet und alles beginnt von vorne.
//Serial.println("Bobbi ist aufgestanden");
if (y==2){ //wenn Bobbi seit 30 Minuten sitzt..
unsigned long actTime = millis(); //Timer
// Anfang BlinkWithoutDelay
if (digitalRead(2) == LOW && x==0) {
// Serial.println("Blink");
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
if (actTime - remTime >= interval){
remTime = actTime;
if(!is_blue){
is_blue = true;
fill_solid(leds, ANZAHL_LEDS, CRGB::Blue);
FastLED.show();
else {
is_blue = false;
fill_solid(leds, ANZAHL_LEDS, CRGB::Black);
FastLED.show();
} // Ende BlinkWithoutDelay....
if (digitalRead(2) == HIGH && x==0) { //Wenn Bobbi den Knopf drückt (/auf den Buzzer haut)---
digitalWrite(3, HIGH); // turn the LED on by making the voltage HIGH
FastLED.show();
random_zaehler = random_int(1, 7);
myDFPlayer.play(random_zaehler); //Play the first mp3 HIER DIE MUSIK EINFÜGEN !!!! Ggf. muss hier noch eingefügt werden, dass das Licht nach Ende des Liedes automatisch ausgeht und y=0 und y=0 gesetzt werden.
myDFPlayer.volume(25);
while(true){
if (myDFPlayer.available()) {
type = getDetail(myDFPlayer.readType()); //Print the detail message from DFPlayer to handle different errors and states.
if(type == DFPlayerPlayFinished){
digitalWrite(3, LOW);
digitalWrite(4, LOW);
FastLED.show();
kraft = 0;
x=0; //alles startet von vorne
y=0; //alles startet von vorne
if (digitalRead(2) == HIGH && x==1) { //Wenn Bobbi den Knopf einzweites Mal drückt (/auf den Buzzer haut)...
digitalWrite(4, LOW); // turn the LED OFF by making the voltage LOW
FastLED.show();
myDFPlayer.pause(); // HIER DIE MUSIK AUS !!!! GGF. muss man sich hier noch um einen Abbruch der Musik kümmern
delay (500);
kraft=0;
x=1;
delay (500);
