The script below is connect to a inductive sensor with a voltage divider
When the arduino boots it isnt running.
After pressing the reset button it's running well.
Any suggestions?
Basic MQTT example with Authentication
- connects to an MQTT server, providing username
and password
- publishes "hello world" to the topic "outTopic"
- subscribes to the topic "inTopic"
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// set pin numbers:
const int pin1 = 3; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int sensor1 = 0; // variable for reading the pushbutton status
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// Update these with values suitable for your network.
byte mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress ip(192, 168, 5, 210);
IPAddress server(192, 168, 5, 204);
void callback(char* topic, byte* payload, unsigned int length) {
// Serial.print("Message arrived [");
// Serial.print(topic);
// Serial.print("] ");
for (int i=0;i<length;i++) {
Serial.print((char)payload[i]);
EthernetClient ethClient;
PubSubClient client(server, 1883, callback, ethClient);
// initialize serial communication:
Serial.println("start");
// initialize the LED pin as an output:
//pinMode(ledPin, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(sensor1, INPUT);
Ethernet.begin(mac, ip);
// Note - the default maximum packet size is 128 bytes. If the
// combined length of clientId, username and password exceed this,
// you will need to increase the value of MQTT_MAX_PACKET_SIZE in
// PubSubClient.h
if (client.connect("arduinoClient", "", "")) {
client.publish("biertap","hello world");
client.subscribe("biertap");
client.loop();
sensor1 = digitalRead(pin1);
if (sensor1 == LOW ) {
buttonState = HIGH;
buttonState = LOW;
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
Serial.println("biertap actie");
client.publish("biertap","actie");
digitalWrite(LED_BUILTIN, HIGH);
// if the current state is LOW then the button
// wend from on to off:
digitalWrite(LED_BUILTIN, LOW);
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
