Hi all,
I am trying to setup a circuit where a brief 5V signal is sent to a DC motor as output after breaking one of two IR beams.
I am using Arduino UNO, IR LED and light-dependent resistors to create the IR beam circuit. The output is connected to a green LED at the moment to test the circuit.
The code is attached below, just for reference, but I am pretty sure the code is OK.
The reason I think that the code is OK (and the actual issue) is the following:
The code works only if I supply power through the USB and have my finger on top of the Arduino USB port.
If I have the USB cable plugged in but I do not touch the Arduino, the output gets triggered randomly now and then, without breaking the IR beams.
If I plug in a 9V/2amp power supply in the barrel jack, or if I use a 9V battery, the output is almost constantly ON, but flickering, again, without breaking of the IR beams.
Since the performance depends on the source of power and me holding a finger over the USB port (grounding issue?) I believe there is something wrong with the Arduino hardware itself.
Any suggestions are greatly appreciated!
int gatePin1 = 3; // gatePin refrs to the pin sendin the 5V to the transistor controlling the feeder DC motor
//int gatePin2 = 4; //extra gatePin for two outputs
int LDR1 = A2;
int LDR2 = A3;
long LDR1value1, LDR1value2;
long LDR2value1, LDR2value2;
//trying to avoid delay()
unsigned long LDR1startMillis;
unsigned long LDR2startMillis;
//unsigned long Pin1startMillis;
unsigned long currentMillis;
const unsigned long period1 = 50;
//const unsigned long period2 = 75; //can use another timer to control the 5V output duration, but not necessary at this point
void setup(){
pinMode(gatePin1, OUTPUT);
//pinMode(gatePin2, OUTPUT);
pinMode(LDR1, INPUT);
pinMode(LDR2, INPUT);
LDR1startMillis = millis();// avoiding delay()
LDR2startMillis = millis();
// Pin1startMillis = millis();
void loop(){
currentMillis = millis();
LDR1value1 = analogRead(LDR1);
//delay(50);
if (currentMillis - LDR1startMillis >= period1) //avoid delay()
LDR1value2 = analogRead(LDR1);
LDR1startMillis = currentMillis;
LDR2value1 = analogRead(LDR2);
//delay(50);
if (currentMillis - LDR2startMillis >= period1) //avoid delay()
LDR2value2 = analogRead(LDR2);
LDR2startMillis = currentMillis;
if (LDR1value2 - LDR1value1 > 10 || LDR2value2 - LDR2value1 > 10)
digitalWrite(gatePin1, HIGH);
delay(75);
digitalWrite(gatePin1, LOW);
