Hello!
I am a newbie trying to make a project for my university.
I am trying to use a joystick module to Scroll and use as a cursor for my Laptop.
Essentially I want the joystick to function in a way that the joystick to have two modes.
One mode to use as a cursor like a mouse (i don't want it to have the mouse_left click, I plan to use a seperate button for that).
The other mode to scroll pages up or down by moving joystick.
I want to implement it in a way that the joystick behaves as a cursor by default. But if the joystick it pressed (and released) it then starts to scroll the page. If it is pressed again, it begins to behave as a cursor once again.
#include <Mouse.h>
int horzPin = A0; // Analog output of horizontal joystick pin
int vertPin = A1; // Analog output of vertical joystick pin
int selPin = 9; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 400; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
int scroll_switch = 0;
bool commandSent = false;
//int invertMouse = 1; //Invert joystick based on orientation
int invertMouse = -1; //Noninverted joystick based on orientation
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
Mouse.begin(); //Init mouse emulation
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
scroll_switch += 1;
// click the left button down
if (scroll_switch % 2 == 0){
if (vertValue != 0){
Mouse.move(0, (invertMouse * (vertValue / sensitivity)), 0);
} // move mouse on y axis
if (horzValue != 0){
Mouse.move((invertMouse * (horzValue / sensitivity)), 0, 0); // move mouse on x axis
else if (scroll_switch % 2 != 0){
if (!commandSent){
Mouse.move(0, 0, 1); // move mouse on y axis
delay(200);
commandSent = true;
else if (!commandSent){
Mouse.move(0, 0, -1);
delay(200);
commandSent = true;
} // move mouse on x axis
Here is my code.
Please help.
Thank you
