I've tried looking through youtube videos and other forum post, but I'm still unable to scroll through and select menus on my lcd screen using the keypad.
I'm using a Mega 2560 and all the pins are connected directly into the Arduino.
I also plan on adding submenus into the program just trying to solve this problem first.
Thank you in advance for the help!
#include<Keypad.h>
#include<Wire.h>
//#include<LCD.h>
#include<LiquidCrystal.h>
/************* LCD SCREEN PIN SETUPS ****************/
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
/**************************************************KEYPAD SETUP**********************************************************************/
const byte numRows = 4; //number of rows on the keypad
const byte numCols = 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols] =
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[numRows] = {36, 34, 32, 30}; //Rows 0 to 3
byte colPins[numCols] = {28, 26, 24, 22}; //Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad = Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
char keypressed;
/*******DEBOUNCING**************/
int count = 0;
int dt = 20; //debounce time ins ms
int switch1Value;
int switch1OldValue;
/*************** MENU CONTROL **********************/
String menuItems[] = {"Intake", "Set Alarm", "Counters", "Random"};
int menuPage = 0;
int maxMenuPages = round(((sizeof(menuItems) / sizeof(String)) / 2) + .5);
int cursorPosition = 0;
// Creating custom characters for the menu display
byte downArrow[8] = {
0b00100, // *
0b00100, // *
0b00100, // *
0b00100, // *
0b00100, // *
0b10101, // * * *
0b01110, // ***
0b00100 // *
byte upArrow[8] = {
0b00100, // *
0b01110, // ***
0b10101, // * * *
0b00100, // *
0b00100, // *
0b00100, // *
0b00100, // *
0b00100 // *
byte menuCursor[8] = {
B01000, // *
B00100, // *
B00010, // *
B00001, // *
B00010, // *
B00100, // *
B01000, // *
B00000 //
/*****************FUNCTION PROTOTYPE*******************/
void main_Menu();
void Cursor();
void main_Menu_Operation();
void menuItem1();
void menuItem2();
void menuItem3();
void menuItem4();
int CheckInput(int k); //checks keypad input
/*************************************************MAIN CODE *****************************/
//clearing and inititalizing lcd screen
lcd.begin(16, 2);
lcd.clear();
// Creates the byte for the 3 custom characters
lcd.createChar(0, menuCursor);
lcd.createChar(1, upArrow);
lcd.createChar(2, downArrow);
char keypressed = myKeypad.getKey();
Serial.println(keypressed);
main_Menu();
Cursor();
switch1Value = keypressed; // value will be 0 if pressed and 1 if not
if ((switch1OldValue == NO_KEY) && (switch1Value != NO_KEY)) //detects falling edge -10
count++; //do your task on falling edge
delay(dt); // delay to prevent unwanted readings
if ((switch1OldValue != NO_KEY) && (switch1Value == NO_KEY)) //rising edge
delay(dt); //adds delay to prevent undesirable readings
switch1OldValue = switch1Value;
Serial.println(count);
void main_Menu()
Serial.print(menuPage);
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(menuItems[menuPage]);
lcd.setCursor(1, 1);
lcd.print(menuItems[menuPage + 1]);
if (menuPage == 0)
lcd.setCursor(15, 1);
lcd.write(byte(2));
else if (menuPage > 0 and menuPage < maxMenuPages)
lcd.write(byte(2));
lcd.setCursor(15, 0);
lcd.write(byte(1));
else if (menuPage == maxMenuPages)
lcd.write(byte(1));
//Function makes sure the cursor is in the correct position
void Cursor()
for (int x = 0; x < 2; x++) //erasing current cursor
lcd.setCursor(0, x);
lcd.print(" ");
if (menuPage % 2 == 0) //menu page is even
if (cursorPosition % 2 == 0) // cursor position is even
lcd.setCursor(0, 0);
lcd.write(byte(0));
if (cursorPosition % 2 != 0) // cursor position is odd
lcd.setCursor(0, 1);
lcd.write(byte(0));
if (menuPage % 2 != 0) //menu page is odd
if (cursorPosition % 2 == 0) //cursor position is even
lcd.write(byte(0));
if (cursorPosition % 2 != 0) //cursor position is odd
lcd.write(byte(0));
if (keypressed != NO_KEY)
switch (keypressed)
case 'A': // if A is pressed
switch (cursorPosition)
case 0:
menuItem1();
case 1:
menuItem2();
case 2:
menuItem3();
case 3:
menuItem4();
//ButtonPressed = 1;
main_Menu();
Cursor();
case '2': // 2 on the keypad serves as the up button
//KEYPAD = 0;
if (menuPage == 0) // start of menu page
cursorPosition = cursorPosition - 1;
cursorPosition = constrain(cursorPosition, 0, ((sizeof(menuItems) / sizeof(String)) - 1));
if (menuPage % 2 == 0 && cursorPosition % 2 == 0) // even page even cursorPosition
menuPage = menuPage - 1;
menuPage = constrain(menuPage, 0, maxMenuPages);
if (menuPage % 2 != 0 && cursorPosition % 2 != 0) // odd menu page and cursorPosition
main_Menu();
Cursor();
case '8': // 8 on keypad is the downward button
//KEYPAD = 0;
if (menuPage % 2 == 0 && cursorPosition % 2 != 0) //even menu page odd cursorPosition
menuPage = menuPage + 1;
if (menuPage % 2 != 0 && cursorPosition % 2 == 0) // odd menuPage even cursorPosition
main_Menu();
Cursor();
default:
int CheckInput(int k) //checks keypad input
int result = 0;
if (k == 'A')
result = 1; //select
if (k == '2')
result = 2;// move up
if (k == '8') //move down
result = 3;
if (k == 'B') // move back
result = 4;
return (result);
void menuItem1() //Intake menu
lcd.clear();
lcd.setCursor(3, 0);
lcd.print("Start Intake Process?");
switch (keypressed)
case 'B': //B will be used as a back button
case 'A' :// something selected
//call intake function
default:
void menuItem2() //Setting dispensing schedule
lcd.clear();
lcd.print("Set Schedule");
switch (keypressed)
//call the alarm function
default:
void menuItem3() //unassigned
lcd.clear();
switch (keypressed)
default:
void menuItem4() //unassigned
lcd.clear();
switch (keypressed)
default:
