This is a prototype I made of a scrolling LED sign. This one is a 5x6 matrix of LEDs. It uses row column indexing to address each LED. All the anodes are hooked up the the rows and all the cathodes are hooked up to the columns. So if I wanted to turn the top left LED on I would set row1 high and column 1 low. I plan on making a bigger version that will hopefully be 5x80 or so using the arduino mega. The video below shows it scrolling "HELLO WORLD" Homemade scrolling LED sign running on arduino - YouTube Sorry for the poor video quality I don't have a good camera. Here's the code:
int Row1 = 2;
int Row2 = 3;
int Row3 = 4;
int Row4 = 5;
int Row5 = 6;
int Col6 = 7;
int Col5 = 8;
int Col4 = 9;
int Col3 = 10;
int Col2 = 11;
int Col1 = 12;
int Tx = 0;
int Ty = 0;
int y = 0;
int z = 0;
int WordSize = 0;
unsigned long t = 0;
//this is what defines a Letter on the most primitive letter
struct BaseLetter {
virtual char get( byte line, byte bit ) = 0;
virtual byte width( void ) = 0;
static const byte NUMBER_OF_LINES = 5;
//Define letters of variable width using this template struct
template<byte size>
struct Letter : public BaseLetter {
Letter( byte l0, byte l1, byte l2, byte l3, byte l4) :
line0(l0),line1(l1),line2(l2),line3(l3),line4(l4) {
unsigned line0 : size;
unsigned line1 : size;
unsigned line2 : size;
unsigned line3 : size;
unsigned line4 : size;
unsigned : 0;
virtual char get( byte line, byte bit ) {
switch (line){
case 0: return (line0&(1<<bit%size)?1:0); break;
case 1: return (line1&(1<<bit%size)?1:0); break;
case 2: return (line2&(1<<bit%size)?1:0); break;
case 3: return (line3&(1<<bit%size)?1:0); break;
case 4: return (line4&(1<<bit%size)?1:0); break;
return -1;
virtual byte width() { return size; }
DEFINE THE LETTERS
Letter<3> A = Letter<3>(
B010,
B101,
B111,
B101,
B101
Letter<3> B = Letter<3>(
B110,
B101,
B110,
B101,
B110
Letter<3> C = Letter<3>(
B011,
B100,
B100,
B100,
B011
Letter<3> D = Letter<3>(
B110,
B101,
B101,
B101,
B110
Letter<3> E = Letter<3>(
B111,
B100,
B111,
B100,
B111
Letter<3> F = Letter<3>(
B111,
B100,
B110,
B100,
B100
Letter<5> G = Letter<5>(
B01110,
B10000,
B10011,
B10001,
B01110
Letter<3> H = Letter<3>(
B101,
B101,
B111,
B101,
B101
Letter<3> I = Letter<3>(
B111,
B010,
B010,
B010,
B111
Letter<3> J = Letter<3>(
B011,
B001,
B001,
B101,
B010
Letter<4> K = Letter<4>(
B1001,
B1010,
B1100,
B1010,
B1001
Letter<3> L = Letter<3>(
B100,
B100,
B100,
B100,
B111
Letter<5> M = Letter<5>(
B10001,
B11011,
B10101,
B10001,
B10001
Letter<5> N = Letter<5>(
B10001,
B11001,
B10101,
B10011,
B10001
Letter<3> O = Letter<3>(
B010,
B101,
B101,
B101,
B010
Letter<3> P = Letter<3>(
B110,
B101,
B110,
B100,
B100
Letter<5> Q = Letter<5>(
B01110,
B10001,
B10101,
B10011,
B01100
Letter<4> R = Letter<4>(
B1110,
B1010,
B1100,
B1010,
B1001
Letter<3> S = Letter<3>(
B011,
B100,
B010,
B001,
B110
Letter<3> T = Letter<3>(
B111,
B010,
B010,
B010,
B010
Letter<3> U = Letter<3>(
B101,
B101,
B101,
B101,
B010
Letter<5> V = Letter<5>(
B10001,
B10001,
B10001,
B01010,
B00100
Letter<5> W = Letter<5>(
B10001,
B10001,
B10001,
B10101,
B01010
Letter<3> X = Letter<3>(
B101,
B101,
B010,
B101,
B101
Letter<3> Y = Letter<3>(
B101,
B101,
B010,
B010,
B010
Letter<3> Z = Letter<3>(
B111,
B001,
B010,
B100,
B111
Letter<1> Ls = Letter<1>(
B0,
B0,
B0,
B0,
B0
Letter<2> Ws = Letter<2>(
B00,
B00,
B00,
B00,
B00
DEFINE THE WORD
const byte WORD_LENGTH = 19;//MAX is around 26
BaseLetter* word1[WORD_LENGTH] = {&H, &Ls, &E, &Ls, &L, &Ls, &L, &Ls, &O, &Ws, &W, &Ls, &O, &Ls, &R, &Ls, &L, &Ls, &D}; //Hello world
//BaseLetter* word1[WORD_LENGTH] = {&T, &Ls, &H, &Ls, &X, &Ws, &A, &Ls, &L, &Ls, &P, &Ls, &H, &Ls, &A, &Ls, &B, &Ls, &E, &Ls, &T, &Ls, &A}; //thx Alphabeta
char Text[5][5*(WORD_LENGTH/2)+(WORD_LENGTH/2)];
pinMode(Row1, OUTPUT);//Row1
pinMode(Row2, OUTPUT);//Row2
pinMode(Row3, OUTPUT);//Row3
pinMode(Row4, OUTPUT);//Row4
pinMode(Row5, OUTPUT);//Row5
pinMode(Col6, OUTPUT);//Col6
pinMode(Col5, OUTPUT);//Col5
pinMode(Col4, OUTPUT);//Col4
pinMode(Col3, OUTPUT);//Col3
pinMode(Col2, OUTPUT);//Col2
pinMode(Col1, OUTPUT);//Col1
for(int i=0; i<WORD_LENGTH; i++){
WordSize = WordSize + (word1[i]->width());
for(Ty=0;Ty<(5*(WORD_LENGTH/2)+(WORD_LENGTH/2));Ty++){
for(Tx=0;Tx<=5;Tx++){
Text[Tx][Ty]=0;
Tx=0;
Ty=0;
for (int wordIndex=0; wordIndex<WORD_LENGTH; wordIndex++){
//loop through all the columns
for (int bit=(word1[wordIndex]->width()-1); bit>=0; bit--){
//loop through all the rows
for (int line=0; line<BaseLetter::NUMBER_OF_LINES; line++){
//print the value at the current letter, at the current line at the current bit
//Serial.print(word1[wordIndex]->get(line,bit),DEC);
Text[Tx][Ty]=int(word1[wordIndex]->get(line,bit));
Tx++;
//Serial.print(Text[Tx][Ty],DEC);
//Serial.println();
Tx=0;
Ty++;
Tx = 0;
Ty = 0;
for(Tx=0;Tx<5;Tx++){
Tx = 0;
Ty = 0;
for(y=0; y <6; y++){
if(t<100){
t++;}
else{
z++;
t=0;}
if(z==((5*(WORD_LENGTH/2)+(WORD_LENGTH/2))-6))
{z=0;}
digitalWrite(Row1, Text[0][y+z]);
digitalWrite(Row2, Text[1][y+z]);
digitalWrite(Row3, Text[2][y+z]);
digitalWrite(Row4, Text[3][y+z]);
digitalWrite(Row5, Text[4][y+z]);
//delay(1000);
if(y==0){
pinMode(Col1,OUTPUT);
digitalWrite(Col1, LOW);
pinMode(Col2,INPUT);
pinMode(Col3,INPUT);
pinMode(Col4,INPUT);
pinMode(Col5,INPUT);
pinMode(Col6,INPUT);}
if(y==1){
//Serial.println("Col2");
pinMode(Col2,OUTPUT);
pinMode(Col1,INPUT);
digitalWrite(Col2, LOW);
if(y==2){
pinMode(Col3,OUTPUT);
digitalWrite(Col3, LOW);
if(y==3){
pinMode(Col4,OUTPUT);
digitalWrite(Col4, LOW);
if(y==4){
pinMode(Col5,OUTPUT);
digitalWrite(Col5, LOW);
if(y==5){
pinMode(Col6,OUTPUT);
digitalWrite(Col6, LOW);}
delay(1);
y=0;
I want to thank AlphaBeta and the others who helped me get this code working. Now I just need to solve my memory problems, I can only have about 26 characters at a time right now because I run out of RAM.
