Scrolling menu program hangs...
I wrote this code (yes I know it's pretty crap but it was quick) for a 16x2 Serial LCD scrolling menu (tested on 20x4 and 16x2) but it's not quite working :(:
#include <NewSoftSerial.h>
NewSoftSerial LCDserial(0, 2);
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void LCDmenudisplay();
void first();
void second();
void third();
void fourth();
void fifth();
  LCDserial.begin(9600);
  menu();
  //nothing to loop but is required in every sketch.
void LCDclear(){
  LCDserial.print(0xFE, BYTE);
  LCDserial.print(0x01, BYTE);
void LCDfirst(){
  LCDserial.print(128, BYTE);
void LCDsecond(){
  LCDserial.print(192, BYTE);
void menu() {
  while(digitalRead(up) == HIGH or digitalRead(down) == HIGH or digitalRead(select) == HIGH){};
  delay(50);
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
  prognumber--;
  else{
    prognumber == 1;
  LCDmenudisplay();
  LCDsecond();
  prognumber++;
  LCDmenudisplay();
  if(line == 1){
    LCDserial.print(143, BYTE);
    LCDserial.print("<");
  else {
    LCDserial.print(207, BYTE);
  while(digitalRead(up) == LOW && digitalRead(down) == LOW && digitalRead(select) == LOW){}
  if(digitalRead(down) == HIGH){
  line++;
  if(line > 2){
  line = 2;
  prognumber++;
  if(prognumber > 4){
  prognumber = 5;
  menu();
  else if(digitalRead(up) == HIGH){
  line--;
  if(line < 1){
  line = 1;
  prognumber--;
  menu();
  else if(digitalRead(select) == HIGH){
  if(line == 1){
    prognumber--;
  switch (prognumber) {
  case 1:
    first();
  case 2:
    second();
  case 3:
    third();
  case 4:
    fourth();
  case 5:
    fifth();
  default:
    first();
void LCDmenudisplay() {
  case 1:
    LCDserial.print("First");
  case 2:
    LCDserial.print("Second");
  case 3:
    LCDserial.print("Third");
  case 4:
    LCDserial.print("Fourth");
  case 5:
    LCDserial.print("Fifth");
  default:
void first() {
  digitalWrite(13, HIGH);
  menu();
void second() {
  menu();
void third() {
  menu();
void fourth() {
  menu();
void fifth() {
  digitalWrite(13, LOW);
  menu();
All seems to work apart from after about 10-20 presses of up/down buttons it hangs and needs resetting.
Anyone got any ideas as to why?
Also if anyone else has any scrolling menu programs they have written then I would be interested in seeing them.
Mowcius
I'm having a hard time following your code. As far as more menu examples, I recall seeing a few different menu libraries in one of the Arduino libraries pages.
Just out of interest, how/where is "or" defined"?
Yeah I'm not surprised and did you? Where? :slight_smile:
Aha! That is a good point. That might be the issue. I had forgotten that it's || not 'or'...
I wonder why it didn't throw up an error for that one. :-?
Mowcius
Hmm. Changing that makes no difference...
Any other ideas?
Any links to these other menus?
Mowcius
hi everyone
I have added some serial debug lines and it appears to jump from 22a to 31 then to 38 and hang there..
void LCDclear(){
void LCDfirst(){
void LCDsecond(){
void menu() {
  Serial.println(" 1");
  Serial.println(" 2");
  delay(50);
  Serial.println(" 3");
  LCDclear();
  Serial.println(" 4");
  LCDfirst();
  Serial.println(" 5");
  if(prognumber > 1){
    Serial.println(" 6");
  prognumber--;
  Serial.println(" 7");
  else{
    Serial.println(" 8");
    prognumber == 1;
  Serial.println(" 9");
  LCDmenudisplay();
  Serial.println(" 10");
  LCDsecond();
  Serial.println(" 11");
  prognumber++;
Serial.println("12 ");
  LCDmenudisplay();
  Serial.println("13 ");
  if(line == 1){
    Serial.println("14 ");
    Serial.println("15 ");
    Serial.println(" 16");
    Serial.println("17 ");
  else {
    Serial.println("18 ");
    Serial.println("19 ");
    Serial.println("20 ");
    Serial.println(" 21");
   Serial.println("22A ");
  Serial.println("22 ");
  delay(50);
    Serial.println(" 23");
  line++;
  Serial.println("24 ");
  if(line > 2){
    Serial.println("25 ");
  line = 2;
  Serial.println(" 26");
  prognumber++;
  Serial.println("27 ");
  if(prognumber > 4){
    Serial.println("28 ");
  prognumber = 5;
Serial.println(" 29");
  Serial.println(" 30");
  menu();
  Serial.println(" 31");
  delay(50);
    Serial.println("32 ");
  line--;
  Serial.println("33 ");
  if(line < 1){
    Serial.println("34 ");
  line = 1;
  Serial.println("35 ");
  prognumber--;
  Serial.println("36 ");
  Serial.println(" 37");
  menu();
  Serial.println("38 ");
  delay(50);
    Serial.println("39 ");
  if(line == 1){
    Serial.println(" 40");
    prognumber--;
    Serial.println("41 ");
  Serial.println("42 ");
  case 1:
Serial.println("43 ");
    first();
  case 2:
  Serial.println("44 ");
    second();
  case 3:
  Serial.println("45 ");
    third();
  case 4:
  Serial.println("46 ");
    fourth();
  case 5:
  Serial.println("47");
    fifth();
   default:
    Serial.println("48");
    first();
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  default:
void first() {
  menu();
void second() {
  menu();
void third() {
  menu();
void fourth() {
  menu();
void fifth() {
  menu();
any ideas????
thanks heaps
ben
Hmm, intriguing...
You wanna add that code ] bracket back in? :slight_smile:
Mowcius
oops fixed
Probably not the source of the problem but still worth fixing...
void menu() {
  delay(50);
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
  prognumber--;
  else{
    prognumber [glow]=[/glow]= 1;  [glow]// Assignment?  Comparison?[/glow]
  LCDmenudisplay();
Yes indeed. Another problem in my code... :frowning:
Mowcius
Looks like plenty of recursion going on :wink: You keep calling menu() - even within menu(). Unchecked recursion on a microcontroller == out of memory fast!
I just removed all calls to menu() other than in loop(). I haven't tested it (but I have compiled it), so don't yell at me!
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void first();
void second();
void third();
void fourth();
void fifth();
  menu();
void LCDclear(){
void LCDfirst(){
void LCDsecond(){
void menu() {
  delay(50);
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
    prognumber--;
  else{
    prognumber = 1;
  LCDmenudisplay();
  LCDsecond();
  prognumber++;
  LCDmenudisplay();
  if(line == 1){
  else {
    line++;
    if(line > 2){
      line = 2;
      prognumber++;
      if(prognumber > 4){
        prognumber = 5;
    line--;
    if(line < 1){
      line = 1;
      prognumber--;
    if(line == 1){
      prognumber--;
    case 1:
      first();
    case 2:
      second();
    case 3:
      third();
    case 4:
      fourth();
    case 5:
      fifth();
    default:
      first();
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  default:
void first() {
void second() {
void third() {
void fourth() {
void fifth() {
b
Brett comes to the rescue again :slight_smile:
It works perfectly now. Well almost.
I am just playing with some delays for debounce but after that it seems good to go.
Mowcius
Latest code with a little delay to help with debouncing :slight_smile:
Seems to work perfectly now.
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void first();
void second();
void third();
void fourth();
void fifth();
  menu();
void LCDclear(){
void LCDfirst(){
void LCDsecond(){
void menu() {
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
    prognumber--;
  else{
    prognumber = 1;
  LCDmenudisplay();
  LCDsecond();
  prognumber++;
  LCDmenudisplay();
  if(line == 1){
  else {
    line++;
    if(line > 2){
      line = 2;
      prognumber++;
      if(prognumber > 4){
        prognumber = 5;
    line--;
    if(line < 1){
      line = 1;
      prognumber--;
    if(line == 1){
      prognumber--;
    case 1:
      first();
    case 2:
      second();
    case 3:
      third();
    case 4:
      fourth();
    case 5:
      fifth();
    default:
      first();
  delay(50);
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  default:
void first() {
void second() {
void third() {
void fourth() {
  delay(100);
  delay(100);
  delay(100);
void fifth() {
Hi Mowcius & bhagman,
I would like to thank you both for all your help especially Mowcius!! and thanks to everyone else who contributed.
I love this community. ;D
thanks all
ben
It works without but I forgot to change this in the latest piece of code:
  while(digitalRead(up) == HIGH || digitalRead(down) == HIGH || digitalRead(select) == HIGH){};
Should be '||' not 'or'
No problem! I love the community too :slight_smile:
Mowcius
int prognumber = 1;
int line = 1;
int down = 8;
int select = 9;
int up = 10;
void menu();
void LCDclear();
void LCDfirst();
void LCDsecond();
void first();
void second();
void third();
void fourth();
void fifth();
  menu();
void LCDclear(){
void LCDfirst(){
void LCDsecond(){
void menu() {
  LCDclear();
  LCDfirst();
  if(prognumber > 1){
    prognumber--;
  else{
    prognumber = 1;
  LCDmenudisplay();
  LCDsecond();
  prognumber++;
  LCDmenudisplay();
  if(line == 1){
  else {
    line++;
    if(line > 2){
      line = 2;
      prognumber++;
      if(prognumber > 4){
        prognumber = 5;
    line--;
    if(line < 1){
      line = 1;
      prognumber--;
    if(line == 1){
      prognumber--;
    case 1:
      first();
    case 2:
      second();
    case 3:
      third();
    case 4:
      fourth();
    case 5:
      fifth();
    default:
      first();
  delay(50);
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
  default:
void first() {
void second() {
void third() {
void fourth() {
  delay(100);
  delay(100);
  delay(100);
void fifth() {
As I never posted up the completely correct code before. :stuck_out_tongue:
I never used it, but here is a menu library:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1240415211
May be could be useful to you.
Cheers,
I have seen that library but it did not do what I wanted it to :wink:
So I wrote some code that did :smiley:
