SCT-013 30A 1V issue and arduino is stop
http://openenergymonitor.org/emon/buildingblocks/how-to-build-an-arduino-energy-monitor-measuring-current-only?page=1
From the link:
I use every component same as schematic. Then I use arduino to send serial to computer.
I can read the current with offset +0.3 of Irms.
The issue is when I power on/off the motor or pump which use current 0-10A the Arduino is latch and send nothing to computer.
  1. Separated DC source.(Not work)
  2. Change burden resistor from 33,18,1K not work.
  3. Change Divider resistor 10K to 470K not work.
  4. Use Watch Dog to reset Arduino when it latch or stop.(Not work)
Any Idea please suggest.
This is my code.
#include <EmonLib.h>
#include <avr/wdt.h>
#include "EmonLib.h"
EnergyMonitor emon1;
  emon1.current(1, 30);
  wdt_enable (WDTO_1S);
  double Irms = emon1.calcIrms(1480);
  Serial.println(Irms);
I assume you know this sensor is for AC, not for DC currents.
Did you measure if there is mid-voltage on the analogue pin (2.5volt with a 5volt Arduino).
Post your code (inside code tags).
Leo..
I just modify as you seen. Please suggest me for more.
Thank you.
Chairat
