SCT 2168
Hi
I want to ask if anyone is used SCT2168 shift register?
Is it the same like 6b595?
Is it the same programming like other shifters?
No, it has constant current drivers for the outputs.
It's very similar to the usual shift registers.
Thank you for your answer.
Can you give some example of programming?
Like 6b595 will be something like that - shiftOut(data_pin, clock_pin, LSBFIRST, B10101010);.
What will be that for SCT2168?
Basically the same but that excerpt doesn't work on the 6b595 on it's own, so don't expect it to work on your chip. Post complete sketches.
No, but I will try to fix your sketches if you post them.
