I have had an idea in my head for almost 20 years and it's time I attempt it. I'm looking to have a conversation on the design. I am skilled enough to build and program it but maybe together we can think of some clever design idea.
Use Case:
Nearing the end of an open water scuba dive you need to return to the boat. Surfacing isn't always safe as boats don't know what the flag means and swimming on the surface is terrible.
1: Swim to within 50 feet of boat without surfacing. From distances as far as 1000ft / 300 meters.
2: Know the distance to the boat in any relative unit. 1-very close ... 10-very far
3: Know the direction to swim or ability to figure it out
4: Divers tool should be more passive to allow it to run at or under 9volts for a few hour total run time
5: Boat tool runs on 12volt house battery, probably active
My concept:
Boat uses house batteries and a subsurface antenna to transmit RF in the range of 20Khz to 100Khz, in 5K blocks (for example) on a 1 second, per 5k, repeating pattern, 20,25,30,...100K,20,25,30... This could provide 16 'ranges' each RF band would attenuate to zero in progressively longer or shorter distance, yet non-directional as I'd need it to be to find the boat, at least the first time.
I (the diver) would have a receiver that looks like a flashlight. The receiver would be recessed and lightly shielded on 2 side. Shielding would add extra attenuation so that I could pan 'left and right' and pick up or drop off any weak range RF. This will provide a relative direction to the strongest sign as every range but the very longest will be shared by many frequencies and hence ranging accuracy and direction can be distilled.
A simple line of LEDs in the classic Red, Yellow, Green will indicate range as each of the 16 LEDs will respond to only one 5Khz RF band. While I swim I can continue to pan for the strongest signal and eventually all the LED will be lite and I should be within range of the boat and safe to surface.
I need to test what frequencies to use to get the 15m to 300m range and work our the Decibels to start with so they fall off evenly as I don't expect they will.
I'm open to ideas but active sonar ranging is far to complex and I don't want use a surface mounted radio on a float wired down to me, too much to break and store.
Ideally I'm looking for wisdom from those with the proper education to add something I haven't read in the other 'underwater RF' posts as they wanted to communicate. I just need datum to navigate from. I have also, mostly read, the ARRL handbook so I think the way water eats RF is my best and simplest design.
For what it's worth, that's my idea. Thanks for reading.
