SD/2.2" TFT LCD Module
Hi Everyone.
I am using a 2.2" TFT LCD with a built in SD Card slot as per the attached pictures.
I have managed to get the TFT working perfectly.
When I then use the standard SD library, I cant find or get any response from the SD card slot. What I also find is that when I try fire up the SD, the TFT speed drops off completely.
Is there a special library for use with this module?
Anyone got experience?
I have also tried removing the entire sketch and just use the SD library but no luck.
On which Arduino? With what code?
