hello,
i'm using an ethernet shield and i'm thinking that there is a conflict between sd and ethernet
indeed with this code
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(5,OUTPUT);
Serial.begin (9600); //initialisation de communication série
if (!SD.begin(4)){//teste la communication avec la carte(pin 4)
Serial.println("Communication impossible");
return; //stoppe le programme
else {
Serial.println("Communication ok !");}
Ethernet.begin (mac); //initialisatio de la communication Ethernet
server.begin();
if (Ethernet.begin( mac) == 0)
{ Serial.println(" FAILED!");
else {
Serial.println(" OK!");
Serial.print(" IP Address: ");
Serial.println( Ethernet.localIP());
Serial.print(" Default Gateway: ");
Serial.println( Ethernet.gatewayIP());
Serial.print(" Subnet Mask: ");
Serial.println( Ethernet.subnetMask());
Serial.print(" DNS Server: ");
Serial.println( Ethernet.dnsServerIP());
else {
i obtain
communication ok (with sd)
ethernet parameters ok
communication impossible
so it looks like that when ethernet is working i can not access to sd card.
#include <SPI.h> //bibliothèqe pour SPI
#include <Ethernet.h> //bibliothèque pour Ethernet
#include <SD.h>
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0xF3, 0x9B}; // tableau pour l'adresse MAC de votre carte
EthernetServer server(80);
int dit;
int temperature;
int masse;
int effectif;
pinMode(A0,INPUT);
pinMode(A1,INPUT);
pinMode(A2,INPUT);
pinMode(5,OUTPUT);
pinMode(4,OUTPUT);
else {
server.begin();
else {
else {
temperature = analogRead (A0);
masse = analogRead (A1);
effectif = analogRead (A2);
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
true;
// send a standard http response header
client.println(F("HTTP/1.1 200 OK"));
client.println(F("Content-Type: text/html"));
client.println(F("Connection: close"));
client.println();
// send web page
client.println(F("<!DOCTYPE html>"));
client.println(F("<html>"));
client.println("<head>");
client.println("<META HTTP-EQUIV=""Refresh"" CONTENT=""5"">");
client.println("<title>Arduino Web Page</title>");
client.println("</META>");
client.println("</head>");
client.println("<body>");
client.println(F(" <div style=""text-align: center; font-weight: bold; color: rgb(255, 102, 0);""><big><big><span style=""font-family: Javanese Text;"">Ma ruche connecte</span>
</big></big></div>"));
client.println(F("<span style=""font-family: Courier New,Courier,monospace;""></span>"));
client.println(F("<table style=""text-align: left; width: 1251px; height: 119px;"" border=""1""cellpadding=""2"" cellspacing=""2"">"));
client.println(F("<tbody>"));
client.println(F("<tr>"));
client.print(F("<td style=""width: 18%;""><span style=""font-weight: bold; font-family: Marlett;""> temperature: "));
client.print(temperature);
client.println(F("</span></td>"));
client.println(F("<td style=""width: 40%;"" colspan=""1"" rowspan=""3""><img src='ruche.jpg'></td>"));
client.println(F(" <td colspan=""1"" rowspan=""3"" align=""undefined"" valign=""undefined"">video</td>"));
client.println("</tr>");
client.println("<tr>");
client.print(F("<td align=""undefined"" valign=""undefined""><span style=""font-weight: bold; font-family: Marlett;"">Masse: "));
client.print(masse);
client.println(F(" </tr>"));
client.println(F(" <tr>"));
client.print(F("<td align=""undefined"" valign=""undefined""><span style=""font-weight: bold; font-family: Marlett;"">Effectif: "));
client.print(effectif);
client.println(F(" </tbody>"));
client.println(F("</table>"));
client.println(F("
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
in the setup at the begining the sd card is detected and i receive the message communication ok
after all the web parameters appear
and at the end of the setup code i receive the message communication impossible meaning that sd card is no more detected
i have tried many thing for exemple manualy write the cs pin at low but nothing works
i’m using arduino uno with this shield :Shield Ethernet EF02029 Elecfreaks - Articles retires | GO TRONIC
