Hi All,
Recently I've added SD card support to my project, it all went well although I had to do a good face-lift to make sure there's enough memory for the highly demanding SD library.
However I have realized that if the microSD card is not present, and I call SD.begin() then any subsequent writes to Ethernet clients is really really slow (I/O is being done finally, but with lots of delays, even few seconds).
If I comment out SD.begin() then everything comes back to normal and Ethernet i/o is super-fast again.
Can you please advise?
This is the code I use in my setup() for initializing the SD card:
// disable W5100 while setting up SD
pinMode(10,OUTPUT);
digitalWrite(10,HIGH);
if (! SD.begin(4)) {
Serial.println(F("Error cannot initialize SD card!"));
SD.begin() calls (among others) Sd2Card.init(), and inside init()'s code I found this lines of code (file Sd2Card.cpp):
that change the contents of the SPI Control and SPI Status registers respectively.
Later on, and because microSD card is on board, control goes to "fail" which simply calls chipSelectHigh() and returns false, but does not revert the contents of the SPI registers.
One solution to work-around this and still leave the library code untouched is to preserve the contents of the spi register and revert them in case of failure. This is how I fixed it in my sketch:
I tried this using a combined TFT/SD-reader that work both with (the same) SPI, but leaving out the SD-card makes the display very slow... Other ideas?
