SD Card and Lora module arduino uno [upd]
Background: When working on the 2 modules separately they were working perfectly.
Problem: In the code attached we tried integrating them but Lora wouldn't receive any data without commenting out parts of the SDC function. Is there a fix to this?
Specifically in this part is where things go bad for us.
Serial.print("Data received: ");
Serial.print(received);
if(received=="ANEMO"){
No matter how much we feed it with TRUE data for the condition from another Lora with these codes it simply shows blank and false.
Please Help this poor lamb. This for our school project. Hopefully, you can spare us some of your time. Thank you so much in advance.
for the CS pins:
Lora: pin 10, SD: pin 5
other SPI pins follow the standard pins.
PS: In the code, we have commented out some of the lines within the SDC function as based on our observation:
myFile = SD.open("HG.txt", FILE_WRITE);
myFile.close();
These 2 lines are the ones causing our Lora to make the data blank in the (String received variable).
Thank you, good sir/ma'am, once again hopefully you can assist me.
#include <SPI.h>
#include <SD.h>
#include <RH_RF95.h>
#define RFM95_CS 10
#define RFM95_RST 9
#define RFM95_INT 2
#define RF95_FREQ 868.0
RH_RF95 rf95(RFM95_CS, RFM95_INT);
unsigned long millisecs;
int cnt;
float valu;
String jh;
int code=1;
String received;
File myFile;
void setup(){
 if (!SD.begin(5)) {
    Serial.println("Card failed, or not present");
    while (1);
  else{
  Serial.println("card initialized.");
  delay(100);
 pinMode(RFM95_RST, OUTPUT);
 digitalWrite(RFM95_RST, HIGH);
 while (!Serial);
 Serial.println("Arduino LoRa RX Test!");
 digitalWrite(RFM95_RST, LOW);
 delay(10);
 delay(10);
 while (!rf95.init()) {
 Serial.println("LoRa radio init failed");
 while (1);
 Serial.println("LoRa radio init OK!");
 if (!rf95.setFrequency(RF95_FREQ)) {
 Serial.println("setFrequency failed");
 while (1);
 Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
 rf95.setTxPower(23, false);
void lorA(){
  while(code==1){
if (rf95.waitAvailableTimeout(1000)){
 Serial.println("dayun ");
 uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
 uint8_t len = sizeof(buf);
 if (rf95.recv(buf, &len)){
 cnt++;
 Serial.print("Data number: ");
 Serial.println(cnt);
 received=(char*)buf;
 uint8_t data[] = "And hello back to you";
 rf95.send(data, sizeof(data));
 rf95.waitPacketSent();
 Serial.println("Sent a reply");
 code=0;
 else{
 Serial.println("Receive failed");
void SDC(){
  while(code==0){
  Serial.println("SDC");
//  File dataFile = SD.open("HG.txt", FILE_WRITE);
//  String dataString="Hans";
//  if (dataFile) {
//  dataFile.println(dataString);
//  dataFile.close();
//    Serial.println("closed");
//    Serial.println(dataString);
    code=1;
//  else {
//    Serial.println("error opening datalog.txt");
void loop(){
  Serial.println("loop");
  lorA();
  Serial.println("mid");
  SDC();
The complete code is attached.
SD_LORA_Hanx_next2.ino (2.07 KB)
