Everything seemed OK the first time I ran it except when it asked for the partition size I made it too big by mistake & the sketch stopped as it should have.
However, now when I try to run it, is stops with the error message that card can't be found.
I looked further & the sketch is expecting to see the card as sda1. But when I ssh into the YUN, I see that it has it as sda2.
Solved it - the SD card was formatted as FAT32 on a windows PC. I re-formatted it as NTFS on a Linux machine & then the YUN saw it at sda1. I would asume formatting as NTFS on a windows machine would be the same.
diver999:
@diver999,
could you mark this thread [SOLVED] in the subject line.
diver999:
My SD card formatted as FAT32 (using the Linux program gparted) appears as sda1.
Yun supports both FAT32 as well as NTFS as file system.
opkg update
opkg list |grep kmod-fs-ntfs
kmod-fs-ntfs - 3.3.8-1 - Kernel module for NTFS filesystem support
opkg list |grep kmod-fs-vfat
kmod-fs-vfat - 3.3.8-1 - Kernel module for VFAT filesystem support
