SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
// re-open the file for reading:
myFile = SD.open("timestamp.txt");
if (myFile) {
Serial.println("timestamp.txt");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
Serial.println("============================================");
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt");
// close the file:
myFile.close();
// nothing happens after setup
Is it normal or is there something wrong with the code ?
if something is wrong with the code where it is ?
and is there a way to edit the timestamp of file when it is created on sd card by arduino (default:XX/XX/2000 ) ?
