SD card can't open file
I'm using the standard SD.h library and the Datalogger example runs fine, but when I attempt to make my own datalogger using a ToF sensor (MTOF17001) (which is giving the correct data in its example code) it can't open the file.
SD Example:
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * analog sensors on analog ins 0, 1, and 2
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10;
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  File dataFile = SD.open("datalog.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
My attempt:
  SD card datalogger
  The circuit:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
  created  24 Nov 2010
  modified 9 Apr 2012
  by Tom Igoe
#include <SPI.h>
#include <SD.h>
int incomingByte = 0;
char sendCommand;
char c;
int con;
int interval;
long distance;
    while (1);
  delay(333);//recover memory time
  dataString += millis() / 1000;
  dataString += ", ";
  sendCommand = 0x55;
  Serial.write(sendCommand);
  sendCommand = 0xAA;
  sendCommand = 0xD3;
  sendCommand = 0x00;
  sendCommand = 0x02;
  sendCommand = 0xD5;
  con = 0;
  distance = 0;
  while (true) {
    if (Serial.available() > 0)
      incomingByte = Serial.read();
      con++;//get next data
      if (con == 6) {
        distance = incomingByte;
      if (con == 7) {
        distance = (distance << 8) + incomingByte;//combine data 6 & 7
        Serial.print("Distance=> ");
        Serial.print(distance);
        dataString += String(distance);
        Serial.println("mm");
    } else {  //no value -> break out the while loop
  writeDat(dataString);
void writeDat(String datas) {
  Serial.println(datas);
  while (!Serial) {
  File dataFile = SD.open("DATALOG.TXT", FILE_WRITE);
  if (dataFile) {
    dataFile.println(datas);
    dataFile.close();
  else {
    Serial.println("error"); //this is the error that is being returned, the sd card is initializing but cant open the file
Working sensor example:
  SHARP Corporation
  MTOF17001 TOF module
  for Arduino Mega2560 V1.0
  Working range : 10cm~120cm (White Card)
  Board Connection
  Arduino   ToF module
  0pin      TXD
  1pin      RXD
  GND       GND
  3.3V      Vcc
  Serial monitor setting
  9600bps
  Example instructions:
  @ Command name:CMD_RD_MM
  @ Send instruction:55 AA D3 00 02 D5
  @ Return instruction:55 AA D3 00z 02 01 02 D8 -> get value 6 & 7 -> 0x0102=258mm
  @ Distance measure data( reply the "8888" when abnormal status)
char sendCommand;
char c;
int con;
int interval;
long distance;
  delay(100);//recover memory time
  sendCommand = 0x55;
  sendCommand = 0xAA;
  sendCommand = 0xD3;
  sendCommand = 0x00;
  sendCommand = 0x02;
  sendCommand = 0xD5;
  con = 0;
  distance = 0;
  while (true) {
      if (con == 6) {
      if (con == 7) {
I don't use String objects, but maybe change
by
dataString += String(millis() / 1000);
There might be other places where you do similar things with numbers.
Not the cause of your problem, but why do you have while (!Serial) in the middle of nowhere?
