SD card code affecting LCD screen output
Hi, so I've built this little device that includes an LCD screen a light sensor and a laser with a data logging shield and SD card on top of my arduino. I want the voltages to read out on my LCD screen and it was working until I tried to put code in for the SD card. Now its reading out random letters and numbers in no apparent order.
Here's my code:
 #include <LiquidCrystal.h>
#include "SD.h"
#include <Wire.h>
#include "RTClib.h"
#define LOG_INTERVAL  1000 // mills between entries
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int sensorPin = A0;
int sensorValue;
float Res = 10.0;
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
void setup(){
  lcd.begin(16,2);
  lcd.clear();
   Serial.print("Initializing SD card...");
   pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    return;
   Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
    Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,time,light");
ECHO_TO_SERIAL;
  Serial.println("millis,time,light");
  ECHO_TO_SERIAL; // attempt to write out the header to the file
void loop(){
{  sensorValue = analogRead(sensorPin);
  float Vout = sensorValue*0.0048828125;
  delay(200);
  Serial.print("Voltages");
  Serial.print(Vout);
  lcd.print("V\t");
  lcd.print(sensorValue);
  delay(200);{
  if(Serial.available()){
    delay(100);
     lcd.clear();}
      DateTime now;
  // delay for the amount of time we want between readings
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  // log milliseconds since starting
  uint32_t m = millis();
  logfile.print(m);           // milliseconds since start
  logfile.print(", ");
#if ECHO_TO_SERIAL
  Serial.print(m);         // milliseconds since start
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  logfile.print(Vout);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(Vout);
Any help or advice much appreciated
Also when I open the Serial monitor, it has voltage readings but every time stamp is 0:0:0
I was able to figure out the LCD issue. I had the RTC and screen using the same pins.
This link helped me figure it out.
http://forum.arduino.cc/index.php?topic=161313.0
If anyone can help with my time stamp issue it'd be appreciated!
Can you verify that your RTC module is returning the correct time by making a new sketch and just print
to serial its now time? That should rule out the RTC being off or running out of battery etc.
If that works maybe use your current sketch and print the now time at the top, and validate that to make sure there still isn't pin conflicts
You are missing a Wire.begin() in your setup.
I do not see any file.close() statements in your SD routines, and the data is not physically written to the card without closing the file.
