Hi, here my code. I have a futek TRS605 torque sensor with an encoder built-in with and arduino UNO R3 with an external SD card module. I'm trying to record a torque value at each 3 deg. and create a table a bit like this:
Torque , angle
15.0 , 3
16.0 , 6
18.0 , 9
[...] etc.
when I'm done with this recording, I switch Off a rocker switch to turn off the data recording and then it would write this table in a data1.txt file on the SD card. then if I switch back on the recording, another table it created and then exported to another file named data2.txt.
But when I try to do it, here's what my serial monitor gives me:
Card initialized.
0 ,, 0 ,, 0
void loop
1 ,, 0 ,, 0
-------> here I switch to HIGH the pin 7 (recordpin) from a rocker switch
confirmSTARTrec
Recording started...
recTABLEdata()
3.00 deg , torque:470.65
no index :1
6.00 deg , torque:484.49
no index :2
9.00 deg , torque:456.81
no index :3
-----> *** here I switch to LOW the pin 7 (recordpin) from the same rocker switch***
st
-----> //*** the st come from the serial.print(stoprecETsavedata) and it freeze here with nothing on my SD card***
Please help!
#include <SPI.h>
#include <SD.h>
const int torquePin = A0; // Pin for torque signal
const int angle1Pin = 2; // Pin for angle signal 1
const int angle2Pin = 3; // Pin for angle signal 2
const int recordPin = 7; // Pin to start/stop recording
const int recordLED = 6; // LED de confirmation pour enregistrement
const int OnLED = 5; // LED de confirmation que tout est ready
---SD card pin plug---
MOSI - pin 11 on Arduino Uno
MISO - pin 12 on Arduino Uno
SCK - pin 13 on Arduino Uno
CS - pin 4
int fileIndex = 1;
bool isRecording = false;
bool carteSDok = false;
File dataFile;
bool memoryfull = false;
int bouttonrecord = 0;
float torque = 0.00;
float angle = 0;
int pulse1 = digitalRead(angle1Pin);
int pulse2 = pulse1;
int resolutionangle = 0;
struct Measurement {
float torque;
float angle;
Measurement measurements[80]; // Adjust size as needed
int measurementIndex = 0;
float readtorque() {
float torquevolt = analogRead(torquePin) * (5.00 / 1023.00);
float torquevalue = torquevolt * 20 * 141.61;
return torquevalue;
//-----SETUP----------------------------------------------------------------------------------
pinMode(torquePin, INPUT);
pinMode(angle1Pin, INPUT);
pinMode(angle2Pin, INPUT);
pinMode(recordPin, INPUT_PULLUP);
pinMode(recordLED, OUTPUT);
pinMode(OnLED, OUTPUT);
digitalWrite(recordLED, LOW);
digitalWrite(OnLED, LOW);
pulse2 = pulse1;
while (!SD.begin(4)) {
Serial.println("Insérer Carte SD");
Serial.println("Card initialized.");
digitalWrite(OnLED, HIGH);
carteSDok = true;
//-------MAIN LOOP--------------------------------------------------------------------------------
if (carteSDok) {
bouttonrecord = digitalRead(recordPin); // vérifie bouttonrec= 1 ou 0
Serial.print(bouttonrecord);
Serial.print(" ,, ");
Serial.print(isRecording);
Serial.println(memoryfull);
if (bouttonrecord == HIGH && !isRecording && !memoryfull) { // bouttonrec= 1 ,, isRecording= 0 ,, memoryfull= 0
confirmSTARTrec(); //switch isrecording --> 1
delay(50);
recTABLEdata(); //switch memoryfull --> 1 ou 0
if (bouttonrecord == LOW && isRecording && !memoryfull) { // bouttonrec= 0 ,, isRecording= 1 ,, memoryfull= 0
stoprecETsavedata(); //switch isrecording --> 0
if (bouttonrecord == HIGH && isRecording && memoryfull) { // bouttonrec= 1 ,, isRecording= 1 ,, memoryfull= 1
while (bouttonrecord == 1) { // doit switcher bouttonrec --> 0 manuellement
delay(2000);
digitalWrite(recordLED, HIGH);
delay(100);
delay(100);
delay(100);
delay(100);
delay(100);
if (bouttonrecord == 0) {
memoryfull = false; //switch memoryfull --> 0
if (!SD.begin(4)) {
handleSDCardRemoval();
Serial.println("void loop");
//---Fonctions-----------------------------------------------------------------------------------
void confirmSTARTrec() { // bouttonrec= N/A ,, isRecording--> 1 ,, memoryfull= N/A
Serial.println("confirmSTARTrec");
isRecording = true;
Serial.println("Recording started...");
angle = 0;
void stoprecETsavedata() { // bouttonrec= N/A ,, isRecording--> 0 ,, memoryfull= N/A
Serial.println("stoprecETsavedata");
Serial.println("Recording stopped.");
delay(20);
saveDataToSD();
void recTABLEdata() { // bouttonrec= N/A ,, isRecording= N/A ,, memoryfull--> 1 ou 0
Serial.println("recTABLEdata()");
bool save = false;
while (bouttonrecord == HIGH) {
if (measurementIndex < 80) {
if (pulse1 != pulse2 && !save) {
angle = angle + 0.5;
pulse2 = pulse1;
resolutionangle++;
if (resolutionangle == 6) {
save = true;
if (save) {
torque = readtorque();
measurements[measurementIndex].angle = angle;
measurements[measurementIndex].torque = torque;
measurementIndex++;
Serial.println("----------------");
Serial.print(angle);
Serial.print(" deg , torque:");
Serial.println(torque);
Serial.print("no index :");
Serial.println(measurementIndex);
save = false;
delay(50);
Serial.println("Memory full");
memoryfull = true;
void handleSDCardRemoval() {
Serial.println("handleSDCardRemoval()");
carteSDok = false;
Serial.println("Carte retirée, problème SD");
delay(300);
delay(300);
Serial.println("Turn off recording");
Serial.println("Card ré-initialisée, tout est ok");
carteSDok = true;
void saveDataToSD() { // à l'intérieur du void stoprecETsavedata()
Serial.println("saveDataToSD()");
Serial.print("dataFile pre:");
Serial.println(dataFile);
delay(20);
char fileName[13];
sprintf(fileName, "data%d.txt", fileIndex);
Serial.print("fileName: ");
Serial.println(fileName);
delay(300);
dataFile = SD.open(fileName, FILE_WRITE);
delay(300);
Serial.print("datafile post: ");
if (dataFile) {
Serial.println("SD en écriture...");
dataFile.println(fileName);
dataFile.println("Torque (lb*po) , Angle (deg)");
for (int i = 0; i < measurementIndex; i++) {
dataFile.print(measurements[i].torque);
dataFile.print(" , ");
dataFile.println(measurements[i].angle);
dataFile.close();
delay(100);
fileIndex++;
Serial.println("Data saved to SD card. fichier: " + String(fileName));
Serial.println("Error opening file.");
