SD card data storage
I want to my mega to record the serial and then create a copy of the text file, but changing the file extension. no or yes?
Once more, in English.
What text file?
Why not just create it with the right extension in the first place?
im just curious to see if i can regenerate an image file on my main connected to the cpu from a binary signal received from a remote unit.
Ah, I see.
Perhaps you should write what you want to post on a piece of paper, and get someone to see if it passes the gibberish test before you start typing. You are 0 for 2 so far in this thread.
I think I follow, but the wibble device with the wobbulator interface may be using a non standard spiffle protocol.
I too have been working on a similar project, but for the spiffle I used a 7% window of reading. When I tried going with the normal 3% F.S. it left purfling in the data stream.
so, in the end, sinusoidal depleneration is the root problem.
if you can get it to work. let us know how you were able to compensate for modial interaction of magneto-reluctance and capacitive diractance.
dave-in-nj:
+10 for that!
oh come on by no means 10 youd made your point at depleneration
ok this is what i was referring to
rms3 binary.txt (12.6 KB)
image to hex.txt (128 KB)
im just curious to see if i can regenerate an image file on my main ...
rms3 binary.txt :
10001001 01010000 01001110 01000111 00001101 00001010 00011010  ...
image to hex.txt:
89 50 4e 47 0d 0a 1a 0d 0a 20 20 20 0d 0a 49 48 44 ...
Your requirements are, sadly, not becoming much clearer.
arduidiot:
Thanks for being a sport and letting us have some fun.
lol i have to be a sport to keep getting advice
