#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
#include <SPI.h>
#include <SD.h>
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
const int chipSelect = 4;
Standalone Sketch to use with a Arduino UNO and a
Sharp Optical Dust Sensor GP2Y1010AU0F
int measurePin = 0; //Connect dust sensor to Arduino A0 pin
int ledPower = 2; //Connect 3 led driver pins of dust sensor to Arduino D2
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
void displaySensorDetails(void)
sensor_t sensor;
bmp.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" hPa");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" hPa");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" hPa");
Serial.println("");
void setup(void)
Serial.println("Pressure Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
while(1);
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
/* Display some basic information on this sensor */
displaySensorDetails();
pinMode(ledPower,OUTPUT);
Arduino loop function, called once 'setup' is complete (your own code
should go here)
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
bmp.getEvent(&event);
/* data type init */
String dataString = "";
String pressString = "";
String altiString = "";
String tempString = "";
String dustString="";
digitalWrite(ledPower,LOW); // power on the LED
delayMicroseconds(samplingTime);
voMeasured = analogRead(measurePin); // read the dust value
delayMicroseconds(deltaTime);
digitalWrite(ledPower,HIGH); // turn the LED off
delayMicroseconds(sleepTime);
// 0 - 5V mapped to 0 - 1023 integer values
// recover voltage
calcVoltage = voMeasured * (5.0 / 1024.0);
// linear eqaution taken from Monitoring your Air Quality
// Chris Nafis (c) 2012
dustDensity = 0.17 * calcVoltage - 0.1;
Serial.print("Raw Signal Value (0-1023): ");
Serial.print(voMeasured);
Serial.print(" - Voltage: ");
Serial.print(calcVoltage);
Serial.print(" - Dust Density: ");
Serial.println(dustDensity); // unit: mg/m3
dustString="- Dust Density: "+String(dustDensity);
/* Display the results (barometric pressure is measure in hPa) */
if (event.pressure)
/* Display atmospheric pressue in hPa */
String pressString = String(event.pressure);
Serial.print("Pressure: ");
Serial.print(pressString);
float temperature;
bmp.getTemperature(&temperature);
tempString = String(temperature);
Serial.print("Temperature: ");
Serial.print(tempString);
Serial.println(" C");
/* Then convert the atmospheric pressure, and SLP to altitude */
/* Update this next line with the current SLP for better results */
float seaLevelPressure = SENSORS_PRESSURE_SEALEVELHPA;
altiString = (bmp.pressureToAltitude(seaLevelPressure, event.pressure));
Serial.print("Altitude: ");
Serial.print(altiString);
Serial.println(" m");
Serial.println("");
dataString = altiString + ", " + pressString + ", " + tempString+", " +dustString;
/*file write init */
File dataFile = SD.open("data.txt", FILE_WRITE);
파일 쓰기 프로세스
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening data.txt");
Serial.println("Sensor error");
I enter this code.When I see the Serial monitor dust measurement(+temperature measurement) is showed. But dust measurement is not saved in SD card(Sorry, I can't use English well,,,_)
