I bought SD card module from WAVGAT and connect all pins as they should be to my arduino UNO.
MOSI -> 11
MISO -> 12
SCK -> 13
CS -> 4
running on 5V
Card formated to FAT16.
When I try the Arduino example for CardInfo or Datalogger, card cannot be initialized.
I know this isn't problem with card because the card works well on GPS shield.
Where can be problem? Can the problem be with the module itself?
If it's a microSD module, it should be ok.
Try connecting CS to pin 10 instead of pin 4, and change the cardinfo example sketch:
const int chipSelect = 4;
const int chipSelect = 10;
Thanks for quick reply.
I have already tried on 10 pin, also on 8 pin, still without success.
Do you have a link to the SD module you're using?
That should be a good module. And you are feeding a solid 5V supply to the module's Vcc pin. And when you've tried 8 and 10 as CS options, you've changed the sketch to match. And you don't have any other devices connected to the SPI pins.
I don't know why it wouldn't work. You could try measuring the output voltage of the module's voltage regulator to make sure it's about 3.3V. Otherwise, I don't know what to suggest.
I have measured it and its 3.3V. I will buy a new one, it is quite cheap, this one looks its broken. Thanks for your time and help.
EDIT:
One tiny contact soldered with tin was disconnected few mikrometers from logic-voltage regulator. Its working well now. It was hardware error.
That's great. Congratulations on finding the problem.
