Here is the code. I did not post it at first because it is over 100 lines long.
#include <avr/pgmspace.h>
#include <SD.h>
#include <SPI.h>
#define BAUDRATE 115200
#define NUMLEDS 150
#define FRAME_DURATION 33
#define NEOPIXEL_PIN 13
#define LED_PIN 5
#define V_SENSE_PIN A0
#define LOW_VOLTAGE_TRIP 220
#define LOW_VOLTAGE_TRIP_HYST 10
#define SD_CS 6
const uint8_t PROGMEM gamma8[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUMLEDS,NEOPIXEL_PIN,NEO_GRB);
File rootDir;
char* animationFileName;
unsigned int activeLeds = 0;
unsigned int numFrames = 0;
boolean lowVoltageDisable = false;
File findAnimationFile(File dir){
if(!dir.isDirectory()){
return File();
File currentFile;
while(true){
currentFile = dir.openNextFile();
if(!currentFile){
return File();
String currentFileName = String(currentFile.name());
if(currentFileName.endsWith(".LAF")){
return currentFile;
currentFile.close();
void listDir(File dir){
unsigned int numFiles = 0;
if(dir.isDirectory()){
File currentFile;
while(true){
if(! currentFile){
if(!currentFile.isDirectory()){
Serial.println(currentFile.name());
numFiles++;
Serial.print(F("Found "));
Serial.print(numFiles);
Serial.println(F(" Files"));
void setup(){
delay(5000);
Serial.begin(BAUDRATE);
strip.begin();
pinMode(LED_PIN,OUTPUT);
Serial.println(F("Loading SD Card"));
if(!SD.begin(SD_CS)){
Serial.println(F("Unable to load SD card, is the SD card pluged in?"));
Serial.println(F("Program will halt."));
while(true); //halt
Serial.println(F("SD card Loaded."));
rootDir = SD.open("/");
Serial.println(F("Serching root for animation files..."));
File animationFile = findAnimationFile(rootDir);
if(!animationFile){
Serial.println(F("Unable to find animation file."));
while(true); //halt
Serial.print(F("Found animation file "));
Serial.println(animationFile.name());
unsigned int animationNumLeds = ((unsigned int)animationFile.read())<<8;
animationNumLeds += animationFile.read();
unsigned int animationNumFrames = ((unsigned int)animationFile.read())<<8;
animationNumFrames += animationFile.read();
Serial.print(F("Animation contains "));
Serial.print(animationNumFrames);
Serial.print(F(" frames at "));
Serial.print(animationNumLeds);
Serial.println(F(" LEDs"));
unsigned long expectedSize = animationNumLeds*animationNumFrames*3+4;
Serial.print(F("Checking file size, Expects "));
Serial.print(expectedSize);
Serial.println(F(" bytes."));
if(expectedSize > animationFile.size()){
Serial.println(F("Size check failed."));
while(true); //halt
Serial.println(F("Size check passed"));
activeLeds = animationNumLeds;
numFrames = animationNumFrames;
animationFileName = animationFile.name();
animationFile.close();
rootDir.close();
Serial.println("Setup complete, animation will start.");
void loop(){
File animationFile = SD.open(animationFileName,FILE_READ);
animationFile.seek(3u);
Serial.print("Starting at ");
Serial.println(animationFile.position());
byte red;
byte green;
byte blue;
for(unsigned int frame = 0; frame < numFrames;frame ++){
unsigned long timeStarted = millis();
if(analogRead(V_SENSE_PIN) <= LOW_VOLTAGE_TRIP){
lowVoltageDisable = true;
}else if(analogRead(V_SENSE_PIN) > (LOW_VOLTAGE_TRIP + LOW_VOLTAGE_TRIP_HYST)){
digitalWrite(LED_PIN, HIGH);
for(unsigned int led = 0; led < activeLeds; led++){
red = animationFile.read();
green = animationFile.read();
blue = animationFile.read();
if(led < NUMLEDS){
if(lowVoltageDisable){
strip.setPixelColor(led, 0, 0, 0);
}else{
strip.setPixelColor(led, pgm_read_byte(&gamma8[red]),
pgm_read_byte(&gamma8[green]),
pgm_read_byte(&gamma8[blue]));
strip.show();
digitalWrite(LED_PIN, LOW);
while((millis() - timeStarted) < FRAME_DURATION); //wait for fram time to end
Serial.println("Frame complete.");
