I am trying to display an image from sd on a 1.8 tft all the sd pins seem to be connected. I get this message on serial monitor "Initializing SD card...failed" when I run this code
Arduino TFT Bitmap Logo example
This example reads an image file from a micro-SD card
and draws it on the screen, at random locations.
In this sketch, the Arduino logo is read from a micro-SD card.
There is a .bmp file included with this sketch.
- open the sketch folder (Ctrl-K or Cmd-K)
- copy the "arduino.bmp" file to a micro-SD
- put the SD into the SD slot of the Arduino TFT module.
This example code is in the public domain.
Created 19 April 2013 by Enrico Gueli
http://www.arduino.cc/en/Tutorial/TFTBitmapLogo
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <TFT.h> // Arduino LCD library
// pin definition for the Uno
#define sd_cs 4
#define lcd_cs 10
#define dc 9
#define rst 8
// pin definition for the Leonardo
//#define sd_cs 8
//#define lcd_cs 7
//#define dc 0
//#define rst 1
TFT TFTscreen = TFT(lcd_cs, dc, rst);
// this variable represents the image to be drawn on screen
PImage logo;
// initialize the GLCD and show a message
// asking the user to open the serial line
TFTscreen.begin();
TFTscreen.background(255, 255, 255);
TFTscreen.stroke(0, 0, 255);
TFTscreen.println();
TFTscreen.println(F("Arduino TFT Bitmap Example"));
TFTscreen.stroke(0, 0, 0);
TFTscreen.println(F("Open serial monitor"));
TFTscreen.println(F("to run the sketch"));
// initialize the serial port: it will be used to
// print some diagnostic info
while (!Serial) {
// wait for serial port to connect. Needed for native USB port only
// clear the GLCD screen before starting
// try to access the SD card. If that fails (e.g.
// no card present), the setup process will stop.
Serial.print(F("Initializing SD card..."));
if (!SD.begin(sd_cs)) {
Serial.println(F("failed!"));
return;
Serial.println(F("OK!"));
// initialize and clear the GLCD screen
TFTscreen.begin();
// now that the SD card can be access, try to load the
// image file.
logo = TFTscreen.loadImage("arduino.bmp");
if (!logo.isValid()) {
Serial.println(F("error while loading arduino.bmp"));
// don't do anything if the image wasn't loaded correctly.
if (logo.isValid() == false) {
return;
Serial.println(F("drawing image"));
// get a random location where to draw the image.
// To avoid the image to be draw outside the screen,
// take into account the image size.
int x = random(TFTscreen.width() - logo.width());
int y = random(TFTscreen.height() - logo.height());
// draw the image to the screen
TFTscreen.image(logo, x, y);
// wait a little bit before drawing again
delay(1500);
I dont know if something is wrong with the sd or it is something else
Have you been able to get the SD card working at all?
For each new device I find/write and example "device prove out code" for the SD this was my code (see below).
Also..
For the Arduino library we'll be discussing, and nearly every other SD library, the card must be formatted FAT16 or FAT32. Some only allow one or the other.
SD card read/write
Mod 01 make file name a string and iterate until we find a unused file name.
Mod 02 add capability to increment filename.
Rev 03 tested successfully on Arduino M0
SD card attached to SPI bus on ICSP Header.
SD Board power = 5V (for large board with EEPROM)
based on code created: Nov 2010 by David A. Mellis, 9 Apr 2012 by Tom Igoe
This code is in the public domain.
driver has a 512 byte buffer then write to SD
Closing the file forces any buffered data to be written to the SD and also updates
the file's directory entry.
If you don't close the file, you will lose all data written the file since it was opened,
not just the last buffer, since the directory entry will not be updated.
#include <SPI.h>
#include <SD.h>
// *** SD Card declarations **************************************************
#define SDCARD_CS_PIN 9
uint16_t fileNumb = 900;
char dataFile[8];
bool SD_Error = false;
File myFile; // create instance of a "File" class
SerialUSB.begin(115200);
delay (2000);
// Initializing SD card....
SPISettings mySetting(1000000,MSBFIRST, SPI_MODE0);
if (!SD.begin(SDCARD_CS_PIN))
{SerialUSB.print("initialization failed");
SD_Error = true;
// loop until we find a file that doesn't already exist.......
do
itoa(fileNumb, dataFile, 10); // (value, Array, base)
const char *extension = ".csv";
strcat(dataFile, extension); // syntax strcat(dest, source)
++fileNumb;
} while (SD.exists(dataFile));
SerialUSB.print("READY TO OPEN FILE FOR WRITING = ");
SerialUSB.println(dataFile);
myFile = SD.open(dataFile, FILE_WRITE); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SerialUSB.println(myFile);
// if the file opened okay, write to it:
if (myFile) {
myFile.println("data from boiler"); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SerialUSB.println("data from boiler");
//SerialUSB.print(" data written to file: ");
myFile.close(); // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
else {
// if the file didn't open, print an error:
SD_Error = true;
SerialUSB.print("SD_Error = ");
SerialUSB.print(SD_Error);
// nothing happens after setup
I run a slightly modified version of your code and the serial monitor tells me this " ha$?tinitialization failedREADY TO OPEN FILE FOR WRITING = 900.csv
0
SD_Error = 1"
I am unsure what the error means
I would consider reformatting the SD card. My original experience was with a card formatted using the SD association formatter (see post six). I don't know if formatting differently could cause your issue or not. At the moment I don't have hardware to test this. I do remember reading one post that suggested I should not format with a PC.
UPDATE: The SD association formatter runs from a PC but formats per the SD assoc spec. Formats differently than the OS format function.
