I am trying to use an SD card for additional memory. I have some code, but of course it doesn't work. Is someone else working on this? I got inspired by several sites:
http://www.zeveland.net/wiki/index.php?title=Computers_for_the_Rest_of_You_-_Personal_Entropy_Monitor
most of the code I got here:
Some background info about mmc:
http://elm-chan.org/docs/mmc/mmc_e.html
But, I have seen to much info at the moment. I will have to pause for a bit. My code:
// modified code for arduino, original code @: http://www.captain.at/electronic-atmega-mmc.php
#define DATAOUT 11 //SD pin 2
#define DATAIN 12 //SD pin 7
#define SPICLOCK 13 //SD pin 5
#define CHIPSELECT 10 //SD pin 1
char sector[512];
byte clr;
char spi_transfer(volatile char data)
SPDR = data; //start the transmission
while (!(SPSR & (1<<SPIF))) //wait for the end of the transmission
return SPDR; //return the received byte
char Command(char befF, long AdrH, long AdrL, char befH)
//sends a command to the SD card
spi_transfer(0xFF);
spi_transfer(befF);
char highHigh = (AdrH >> 8);
spi_transfer(highHigh);
spi_transfer(AdrH);
char highLow = (AdrL >> 8);
spi_transfer(highLow);
spi_transfer(AdrL);
spi_transfer(befH);
spi_transfer(0xFF);
return spi_transfer(0xFF);
char MMC_init()
char i,c=0xAA;
digitalWrite(CHIPSELECT, HIGH); //disable the SD card
for (i=0; i<10; i++) //send 10*8=80 clock pulses
spi_transfer(0xFF);
digitalWrite(CHIPSELECT, LOW); //enable the SD card
//send CMD0 to put card in SPI mode
Command(0x00, 0 , 0, 0x95);
delay(2);
//c = (Command(0x40, 0,0,0x95));
while (c != 0x01)
Serial.print(c, HEX);
Serial.print(" ");
c =(Command(0x40, 0,0,0x95));
return c;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK, OUTPUT);
pinMode(CHIPSELECT, OUTPUT);
// SPCR = 01010000
//interrupt disabled,spi enabled,msb 1st,master,clk low when idle,
//sample on leading edge of clk,system clock/4 rate (fastest)
SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);
clr=SPSR;
clr=SPDR;
Serial.println("starting up");
void fillram()
int i,c;
char mystring[18] = "bigengineer@work ";
c = 0;
for (i=0;i<=512;i++)
sector[i] = mystring[c];
c++;
if (c>17) c = 0;
//Serial.println(mystring);
int writeramtommc(void)
int i;
char c;
if (Command(0x58, 0, 512, 0xFF) != 0)
Serial.println("MMC write error 1");
return 1;
spi_transfer(0xFF);
spi_transfer(0xFF);
spi_transfer(0xFE);
for (i=0;i<512;i++) spi_transfer(sector[i]);
spi_transfer(0xFF); //2 dummy bytes
spi_transfer(0xFF);
c = spi_transfer(0xFF);
c &= 0x1F;
if (c != 0x05)
Serial.print("MMC write error c: ");
Serial.println(c, HEX);
return 1;
//wait until MMC is not busy anymore
while(spi_transfer(0xFF) != (0xFF));
return 0;
char readmmc()
int i;
if (Command(0x51, 0, 512, 0xFF))
Serial.println("MMC read error 1");
return 1;
//wait for 0xFE
while(spi_transfer(0xFF) != (0xFE));
for (i = 0;i<512;i++) Serial.print(spi_transfer(0xFF));
spi_transfer(0xFF);
Serial.println("end of read");
return 0;
char c;
fillram();
c = MMC_init();
Serial.print("MMC OK c: ");
writeramtommc();
readmmc();
delay(2000);
